383 Sonoramic Twin Turbo #1041627
07/27/11 08:27 PM
07/27/11 08:27 PM
WI
61 NYer Convt Offline OP
WI
Ok guys. Im new to turbo stuff. I know how they work but thats about it. Do you think twin turbos could be used on a 383 with the sonoramic dual quad cross ram? I just bought a 61 New Yorker 2 door hardtop that I was thinking on doing this to. I really want to use the sonoramic intake and I really want twin turbos. any advice would be awesome.
Re: 383 Sonoramic Twin Turbo [Re: 61 NYer Convt] #1041628
07/27/11 10:47 PM
07/27/11 10:47 PM
St.Louis ,Mo.
72sat Offline
72sat  Offline
St.Louis ,Mo.
it can be done,but it will require alot of plumming.check this site for know how. http://www.theturboforums.com/smf/index.php
Re: 383 Sonoramic Twin Turbo [Re: 72sat] #1041629
07/28/11 11:28 AM
07/28/11 11:28 AM
IL
furious70 Offline
furious70  Offline
IL
I don't know what the 61 front subframe looks like but it might not be that bad. You might be able to use the 62-65 B body rear dump logs flipped side to side to face forward, mount the turbos there, run the downpipe under all that, and run the cold side up and back to each carb. Would be cool looking for sure!
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: 383 Sonoramic Twin Turbo [Re: 61 NYer Convt] #1041630
07/28/11 02:21 PM
07/28/11 02:21 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
you can make anything work, it's just how deep are your pockets
Coming soon!!!!
Re: 383 Sonoramic Twin Turbo [Re: Mr.Yuck] #1041631
07/28/11 02:46 PM
07/28/11 02:46 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
It would look great, but the turbos would over ride the somoramic effect of the manifold, not really worth the trouble. There is enought plumbing on a factory set up before adding any turbo. The control arm mount is near the front exhaust ports so not much hope of backwards manifolds fitting.
Re: 383 Sonoramic Twin Turbo [Re: NANKET] #1041632
07/28/11 03:15 PM
07/28/11 03:15 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
what about rear mount turbos?
Re: 383 Sonoramic Twin Turbo [Re: NANKET] #1041633
08/19/11 08:00 PM
08/19/11 08:00 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
"overide" or just the move tuning band? Please explain
Re: 383 Sonoramic Twin Turbo [Re: jcc] #1041634
08/19/11 11:13 PM
08/19/11 11:13 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
in 1960 andy granetelli ran two paxtons on a 413 long ram 300f. i think he went 176mph on the sand at daytona. if i remember correctly the same car went 190+mph at bonneville the following year. the power adder will negate the ram effect but the ram effect is actually a slight supercharging effect. anyhow, go for it!
Re: 383 Sonoramic Twin Turbo [Re: lewtot184] #1041635
08/20/11 11:48 AM
08/20/11 11:48 AM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
I think the trick with this set up would be synchronization. There is no common tract. The carb on the left could be seeing 5psi and the carb on the right could be seeing 15. Also, the left carb would be fed by the right turbo and vice/versa. Not things that can't be overcome, but something to think about. I think it would be a neat set up.
Re: 383 Sonoramic Twin Turbo [Re: TRENDZ] #1041636
08/20/11 02:35 PM
08/20/11 02:35 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
the intakes were designed with a balance tube. if they're not deleted everything should work.
Re: 383 Sonoramic Twin Turbo [Re: lewtot184] #1041637
08/20/11 08:50 PM
08/20/11 08:50 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
An explanation as to why would be enlightning, and of course that statement also means, I guess, no turbo cars have/need any intake tuned ports also, because it would negate the power adder?
Re: 383 Sonoramic Twin Turbo [Re: jcc] #1041638
08/20/11 09:28 PM
08/20/11 09:28 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
difference between pressure and vacuum
Re: 383 Sonoramic Twin Turbo [Re: lewtot184] #1041639
08/21/11 10:01 PM
08/21/11 10:01 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Well first, air fuel mixture inside an intake is never a complete vacum, it always has mass, it is also under most conditions moving, and the primary basis of the the long ram was using momentum of the above to extra pack the cylinder as the intake was closing. However there are a number of other variables, way over my head, regarding sonic pulses that also are the black magic of intake manifold design. They are both effected and tuned according to many variables, including cross section, surface roughness, geometry, wet or dry, fuel density, temperature, velocity, cam timing, compression, etc, etc. The main effected variable in turboing regarding ram manifold tuning would be a charge density increase, and maybe related varibale would be increase back pressure from the turbo, but I suspect that is more a cam timing variable. Therefore based on my simple explanation versus yours, I complelety disagree with your comment that a long ram intake "negates" the power adder.
Re: 383 Sonoramic Twin Turbo [Re: jcc] #1041640
08/22/11 11:57 AM
08/22/11 11:57 AM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
I think he meant that the power adder negates the benefit of the long ram.
- Stu Harmon
Re: 383 Sonoramic Twin Turbo [Re: feets] #1041641
08/22/11 01:07 PM
08/22/11 01:07 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
I simply can't resist the temptation to use the hot button word here "irregardless" , it is still an incorrect conclusion. The long ram benefit still exists.
Re: 383 Sonoramic Twin Turbo [Re: jcc] #1041642
08/23/11 12:35 PM
08/23/11 12:35 PM
IL
furious70 Offline
furious70  Offline
IL
I think 'negate' is a very poor word here. The more appropriate word IMO is 'override'. The turbos will override any ram effect with their greater ability to create increased pressure.
Whether the turbos would have any effect on the intake pulsing when the intake tract is under vacuum would be a very interesting question however. It would be in the same list of questions as 'were the long rams tuned only at WOT or at partial load'
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: 383 Sonoramic Twin Turbo [Re: furious70] #1041643
08/23/11 01:02 PM
08/23/11 01:02 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
I think it would depend on whether we were using blow-thru or draw-thru, also. What would happen when that pressure wave hits a closed valve, then reverses up the intake tract... right into a spinning rotor???
Re: 383 Sonoramic Twin Turbo [Re: Fury Fan] #1041644
08/24/11 11:26 AM
08/24/11 11:26 AM
IL
furious70 Offline
furious70  Offline
IL
That's going to happen in every engine though, right? It's just these manifolds were tuned for a specific range.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: 383 Sonoramic Twin Turbo [Re: furious70] #1041645
08/24/11 12:03 PM
08/24/11 12:03 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
I ws merely thinking that in blow-thru the pressure wave hits the throttle blades first, but in a draw-thru the wave would hit a wildly-spinning rotor.
Since we're just talkign hypothetically (unless soemone actually builds one), I don't think we'll ever really know how well it works. No good test data, no control group. What might the placebo be?
Re: 383 Sonoramic Twin Turbo [Re: furious70] #1041646
08/25/11 06:58 AM
08/25/11 06:58 AM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
Based on what I know from turbocharging 2.2 and 2.5 engines I can assure you even at high boost pressures the runner tuning still impacts the engines operating range.
If anything it tends to magnify the effect.
