Lets see pics of how you mounted your HHR fan? #1041581
07/27/11 06:39 PM
07/27/11 06:39 PM
ohio
HEMIDARTS Offline OP
ohio
So i just got my HHR fan today.
I layed it on the radiator and it does not fit.
It is not as wide as my radiator.
I measured the outside tabs and they are 26 inches.
Please post any pics you have of your HHR fan mounted.
And please give the dimensions of the fan and radiator.
Thanks!
Re: Lets see pics of how you mounted your HHR fan? [Re: HEMIDARTS] #1041582
07/28/11 08:56 AM
07/28/11 08:56 AM
akron ohio
moparmanjr Offline
moparmanjr  Offline
akron ohio
has anyone mounted one of these
Re: Lets see pics of how you mounted your HHR fan? [Re: moparmanjr] #1041583
07/28/11 09:36 AM
07/28/11 09:36 AM
tboomer Offline
tboomer  Offline
Matt...There may be some pics in this thread...
https://board.moparts.org/ubbthreads/show...&PHPSESSID=
Re: Lets see pics of how you mounted your HHR fan? [Re: HEMIDARTS] #1041584
07/28/11 10:18 AM
07/28/11 10:18 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Thanks!
I'll take a couple of pics and show you how I did
it... it fit my radiator perfectly when I cut the
tabs off the sides
Re: Lets see pics of how you mounted your HHR fan? [Re: HEMIDARTS] #1041585
07/28/11 10:52 AM
07/28/11 10:52 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Here ya go Matt... the core of my radiator is 22.5 X 18
heres a couple pics
Re: Lets see pics of how you mounted your HHR fan? [Re: MR_P_BODY] #1041586
07/28/11 10:54 AM
07/28/11 10:54 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Drivers side
Re: Lets see pics of how you mounted your HHR fan? [Re: MR_P_BODY] #1041587
07/28/11 10:57 AM
07/28/11 10:57 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Last one... the top and bottom of the shroud are
mounted the same way
Re: Lets see pics of how you mounted your HHR fan? [Re: tboomer] #1041588
07/28/11 11:15 AM
07/28/11 11:15 AM
ohio
ohio
Thanks for the link Ted!
And thanks for the pics Mr.P!
I am going to go and take some pics of what i got.
Re: Lets see pics of how you mounted your HHR fan? [Re: MR_P_BODY] #1041589
07/28/11 11:23 AM
07/28/11 11:23 AM
Indy
FlyFish Offline
FlyFish  Offline
Indy
I don't have a pic handy, but I just used four ~7 inch pieces of metal strap and bolted them to the shroud and the core support...2 on the topside, 2 on the bottom (it pulls the fan back against the radiator). I also used some weather stripping to make a good seal on the vertical sides.
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
Re: Lets see pics of how you mounted your HHR fan? [Re: HEMIDARTS] #1041590
07/28/11 11:28 AM
07/28/11 11:28 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I'm going to add 3 or 4 flapper doors so it has more
air flow near the perimeter while at speed... I have
hear of guys getting hot while at speed but they are
fine at 35 or so... being that mine leans rearward so
much I am going to use plastic as a door but I need
to determine how thick so it opens at a certain speed/air flow
Re: Lets see pics of how you mounted your HHR fan? [Re: MR_P_BODY] #1041591
07/28/11 11:51 AM
07/28/11 11:51 AM
ohio
ohio
Here are the pics i took.
The fan does not fit my radiator at all.
Re: Lets see pics of how you mounted your HHR fan? [Re: HEMIDARTS] #1041592
07/28/11 11:52 AM
07/28/11 11:52 AM
ohio
ohio
2. The fan is too tall and not wide enough for my rad.
Re: Lets see pics of how you mounted your HHR fan? [Re: HEMIDARTS] #1041593
07/28/11 11:52 AM
07/28/11 11:52 AM
ohio
ohio
3. The fan hits both of my outlets.
Re: Lets see pics of how you mounted your HHR fan? [Re: HEMIDARTS] #1041594
07/28/11 11:53 AM
07/28/11 11:53 AM
ohio
ohio
4. The is how it sits on the top side and bottom side.
Re: Lets see pics of how you mounted your HHR fan? [Re: HEMIDARTS] #1041595
07/28/11 11:53 AM
07/28/11 11:53 AM
ohio
ohio
5.It is angled because of it hitting the outlets.
Re: Lets see pics of how you mounted your HHR fan? [Re: HEMIDARTS] #1041596
07/28/11 11:54 AM
07/28/11 11:54 AM
ohio
ohio
6.From the top of my core to the bottom inside is 16 "
Re: Lets see pics of how you mounted your HHR fan? [Re: HEMIDARTS] #1041597
07/28/11 11:54 AM
07/28/11 11:54 AM
ohio
ohio
7.from side to side my mounting brackets are almost 28
Re: Lets see pics of how you mounted your HHR fan? [Re: HEMIDARTS] #1041598
07/28/11 11:54 AM
07/28/11 11:54 AM
ohio
ohio
9.from side to side my core is 25" inside the mounting brackets.
Re: Lets see pics of how you mounted your HHR fan? [Re: HEMIDARTS] #1041599
07/28/11 11:55 AM
07/28/11 11:55 AM
ohio
ohio
10.The fan is 22 inside the tabs.
Re: Lets see pics of how you mounted your HHR fan? [Re: HEMIDARTS] #1041600
07/28/11 11:55 AM
07/28/11 11:55 AM
ohio
ohio
11. last one. the fan is 25 -1/2 to the tabs.
