Re: 727 torque converter interchange
[Re: chargersNW]
#1040856
07/26/11 10:59 PM
07/26/11 10:59 PM
Posts: 2,006 s. e. pa.
calrobb2000
s. e. pa.
hi sounds good . you may want to research farther as some 360 an some 440 used the same balancing as i recall ? if so you can use it as is . ![](/ubbthreads/images/graemlins/beer.gif)
[Re: chargersNW]
#1040857
07/27/11 01:55 PM
07/27/11 01:55 PM
Posts: 1,051 Slidell, La.
doctor_mopar
Slidell, La.
The 360 and 440 do not use the same balance weights on the converters. You said the 440 came out of a 47 Plymouth ! Interesting ! You should be good if you take the old weight off, and use a B&M plate for the 360. Just make sure you get the correct plate for Magnum or Non Magnum depending which engine you have.
------------------------ It doesn't matter what you do.........As long as you look good doing it !
