Page 1 of 3 1 2 3
E body wind noise #104065
08/12/08 10:30 PM
08/12/08 10:30 PM
Salem
Grizzly Offline OP
Moparts Proctologist
Grizzly  Offline OP
Salem
There was a post on this some time ago, I did a search and could not find it:
I am in the process of trying to find out where the "e body whistle" is coming from:
I taped every exposed moulding edge on the windshield. Still whistles.
I taped over the hood and fender gaps. Still whistles.
I taped over the leading edge of the doors. Still whistles.
The car is covered in green masking tape and the whistle is present and annoying as ever.
I have experienced this in both a 'Cuda and a Challenger, so I think it is safe to say that the noise is not coming from the grill shape or header panel. Could it be coming from the rad support? How about underneath the car?
Has anyone else had this, and, if so, what did you do to fix it?
Mo' Farts
Moderated by "tbagger".
Re: E body wind noise [Re: Grizzly] #104066
08/12/08 10:52 PM
08/12/08 10:52 PM
Renton, Wa.
Classof70Chally Offline
super gas
super gas
Renton, Wa.
My sig car whistles at 30 to 35 mph with the top up or down. Sounds like it's coming from the drivers side. I'm pretty sure it's a 'factory installed option'!
Re: E body wind noise [Re: Classof70Chally] #104067
08/13/08 11:46 AM
08/13/08 11:46 AM
Salem
Grizzly Offline OP
Grizzly  Offline OP
Salem
Still open to suggestions.....
Mo' Farts
Re: E body wind noise [Re: Grizzly] #104068
08/13/08 11:49 AM
08/13/08 11:49 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Is it coming from the front widows? I got inside my doors and adjusted the glass so it sealed against the weather stripping better, it helped a bunch.
Re: E body wind noise [Re: Grizzly] #104069
08/13/08 12:03 PM
08/13/08 12:03 PM
Upstate, NY
sixpack4spd Offline
sixpack4spd  Offline
Upstate, NY
Buy a B-body???
Re: E body wind noise [Re: Grizzly] #104070
08/13/08 12:12 PM
08/13/08 12:12 PM
La Verne, CA
lakerism Offline
lakerism  Offline
La Verne, CA
There are these clear plastic/celophane-like sheets that are supposed to block the wind that install between the inside of the door and the door panel. They are often gone/rotted so I never knew they were supposed to be there, you can find them on e-bag...
Re: E body wind noise [Re: lakerism] #104071
08/13/08 12:21 PM
08/13/08 12:21 PM
Los Angeles, CA
JF_Moparts Offline
JF_Moparts  Offline
Los Angeles, CA
Could it be a hairline crack in the heater box? The ventilation system air buffets around in there and any crack will cause a whistle.
Re: E body wind noise [Re: sixpack4spd] #104072
08/13/08 12:28 PM
08/13/08 12:28 PM
Salem
Grizzly Offline OP
Grizzly  Offline OP
Salem
Buy a B-body???
You got me there!
Here, take this: A ride in a '69 Chrysler 300 "C" body, at any speed, makes you wonder if B's and E's really came from the same manufacturer!
Mo' Farts
Re: E body wind noise [Re: Grizzly] #104073
08/13/08 01:36 PM
08/13/08 01:36 PM
Pa
GaryB Offline
super street
GaryB  Offline
super street
Pa
I have owned two challengers one was a hard top and the current one is a convertable and both whistle. There have been many discussions on this board throughout the years and no one has found the source of the whistle. Good luck finding it. If I was you I would work on something else as I doubt that you will find it.
Re: E body wind noise [Re: GaryB] #104074
08/13/08 01:38 PM
08/13/08 01:38 PM
New Mexico
UCUDANT Offline
Troll Hunter
UCUDANT  Offline
Troll Hunter
New Mexico
No other car has a cowl like the E body... try tapin up those plactic grilles and see what happens
Re: E body wind noise [Re: UCUDANT] #104075
08/13/08 03:00 PM
08/13/08 03:00 PM
Buzzard County, FL
IronWolf Offline
IronWolf  Offline
Buzzard County, FL
+1 . I had no whistle until I installed a FG hood with open scoops. As far as I can tell, the air is whooshing/whistling through those grilles on the cowl.
I will just turn up the radio/CD when I install one...
Re: E body wind noise [Re: IronWolf] #104076
08/13/08 10:09 PM
08/13/08 10:09 PM
Salem
Grizzly Offline OP
Grizzly  Offline OP
Salem
Challenger1, lakerism, jfmoparts, ucudant and ironwolf, thanks for the suggestions. I will try everything and then some.
Mo' Farts
Re: E body wind noise [Re: UCUDANT] #104077
08/15/08 12:29 AM
08/15/08 12:29 AM
Salem
Grizzly Offline OP
Grizzly  Offline OP
Salem
I put a full width towel folded in half across the cowl screens, from fender to fender. It also covered from the windshield wipers all the way to the ballast resistor. Shut the hood on it and drove.
Still whistles.
Mo' Farts
Re: E body wind noise [Re: Grizzly] #104078
08/15/08 12:43 AM
08/15/08 12:43 AM
Tustin, CA
P
pishta Offline
pishta  Offline
P
Tustin, CA
Is it the side mirrors? Common to both...My Breeze side mirror supports look like airfoils.
Re: E body wind noise [Re: pishta] #104079
08/15/08 07:56 PM
08/15/08 07:56 PM
Salem
Grizzly Offline OP
Grizzly  Offline OP
Salem
It really does sound like it is coming from the mirror, but as you speed up the sound moves to the center of the windshield.
Also, putting your hand out the window and blocking airflow to the mirror has no effect.
Mo' Farts
Re: E body wind noise [Re: Grizzly] #104080
08/16/08 09:07 PM
08/16/08 09:07 PM
middle of the country
aar1 Offline
aar1  Offline
I have the same problem and have never figured it out. How about air coming up inside the steering column? Is that possible?
Re: E body wind noise [Re: aar1] #104081
08/16/08 09:11 PM
08/16/08 09:11 PM
New Mexico
UCUDANT Offline
Troll Hunter
UCUDANT  Offline
Troll Hunter
New Mexico
These can help you find those pesky hard to find noises that only occur during overt the road conditions
http://www.etoolcart.com/wirelesschassisears-wirelessjsp97202.aspx
Re: E body wind noise [Re: UCUDANT] #104082
08/16/08 10:38 PM
08/16/08 10:38 PM
Ky
jt4406 Offline
jt4406  Offline
Ky
Did you try taping up the gap between the hood and windshield (covering the wipers and bridging the gap with tape? Or maybe the gap between the fenders and hood? or maybe the door handle, both bodies use the same basic handles.
jt
Yeah, it's hopped up to over 160...
Re: E body wind noise [Re: jt4406] #104083
08/16/08 11:10 PM
08/16/08 11:10 PM
Salem
Grizzly Offline OP
Grizzly  Offline OP
Salem
jt
When I put the towel in the cowl it covered everything and closed the gap where the wipers are. Door handles are a good suggestion.
Right now I am looking at all the bracing in the front of the car. There is one vertical support in particular that is in the very center, behind the licence plate holder that has a channel shape to it.
I can't drive the car every day, but everytime I have it out I try something. This will take some time to do, but when I find it, you folks will be the first to know.
Ucudant: Great suggestion, I have heard of something similar that was like a stethoscope.
Cuda, lower grill opening:
Mo' Farts
Re: E body wind noise [Re: Grizzly] #104084
08/16/08 11:11 PM
08/16/08 11:11 PM
Salem
Grizzly Offline OP
Grizzly  Offline OP
Salem
Challenger, same view:
Mo' Farts
Page 1 of 3 1 2 3
