E body wind noise
#104065
08/12/08 10:30 PM
08/12/08 10:30 PM
Posts: 6,021 Salem
Grizzly
Moparts Proctologist
Salem
There was a post on this some time ago, I did a search and could not find it:
I am in the process of trying to find out where the "e body whistle" is coming from:
I taped every exposed moulding edge on the windshield. Still whistles.
I taped over the hood and fender gaps. Still whistles.
I taped over the leading edge of the doors. Still whistles.
The car is covered in green masking tape and the whistle is present and annoying as ever.
I have experienced this in both a 'Cuda and a Challenger, so I think it is safe to say that the noise is not coming from the grill shape or header panel. Could it be coming from the rad support? How about underneath the car?
Has anyone else had this, and, if so, what did you do to fix it?
Mo' Farts
Moderated by "tbagger".
Re: E body wind noise
[Re: UCUDANT]
#104075
08/13/08 03:00 PM
08/13/08 03:00 PM
Posts: 1,359 Buzzard County, FL
IronWolf
Buzzard County, FL
No other car has a cowl like the E body... try tapin up those plactic grilles and see what happens
+1 . I had no whistle until I installed a FG hood with open scoops. As far as I can tell, the air is whooshing/whistling through those grilles on the cowl.
I will just turn up the radio/CD when I install one...
[Re: IronWolf]
#104076
08/13/08 10:09 PM
08/13/08 10:09 PM
Posts: 6,021 Salem
Grizzly
Salem
Challenger1, lakerism, jfmoparts, ucudant and ironwolf, thanks for the suggestions. I will try everything and then some.
Mo' Farts
[Re: pishta]
#104079
08/15/08 07:56 PM
08/15/08 07:56 PM
Posts: 6,021 Salem
Grizzly
Salem
It really does sound like it is coming from the mirror, but as you speed up the sound moves to the center of the windshield.
Also, putting your hand out the window and blocking airflow to the mirror has no effect.
Mo' Farts
[Re: UCUDANT]
#104082
08/16/08 10:38 PM
08/16/08 10:38 PM
Posts: 1,567 Ky
jt4406
Ky
Did you try taping up the gap between the hood and windshield (covering the wipers and bridging the gap with tape? Or maybe the gap between the fenders and hood? or maybe the door handle, both bodies use the same basic handles. jt
Yeah, it's hopped up to over 160...
