04 sebring issues
#1040475
07/26/11 02:28 PM
07/26/11 02:28 PM
Posts: 12,478 Kalispell Mt.
HotRodDave
Kalispell Mt.
So I picked up a real nice sebring for dirt cheap, another shop in town told her it needed a huge list of things, some it needed some it didn't. It came to the other shop because of a no start issue, they told her it needed a fuel pump as well as all the other stuff, she didn't want to put any money in it and the shop told them about me being a mopar nut so she called me and I bought the car, through a fuel preasure gauge on it and 55PSI. Checked for codes No codes. Checked for spark and it was real intermitant so I through some coils on off a 2.7 I replaced a while back and same thing, swapped in used crank sensor, same thing, swapped in used cam sensor same thing, unplugged cam sensor and car starts right up and runs perfect so I order a new one and while I am waiting on it to get here I replaced the water pump because it was leaking horendously, still runs good with sensor un plugged, new cam sensor gets here put it in and car won't start, un plug it and all is well I am getting a good 5v signal to it, what to check next?
Re: 04 sebring issues
[Re: IcorkSOAK]
#1040477
07/26/11 10:52 PM
07/26/11 10:52 PM
Posts: 10,673 S.E.Ohio
Magnumguy
S.E.Ohio
Don't you just LOVE these pure E-cars ? ...!!
Time for a 360 and a TQ !
A-men!!
[Re: HotRodDave]
#1040478
07/26/11 11:19 PM
07/26/11 11:19 PM
Posts: 1,130 Dayton, Ohio
wldtm
Dayton, Ohio
It sounded like at first you had a bad sensor taking down the 5volt reference. But you put a new sensor in it, so i figured that would have solved it. However, with the sensor plugged in, do you have 5v key on, engine off????
when you unplugged it did it set a Cam Sensor Circuit High code? (I am assuming you have a scan tool) What about if you short the CAM signal circuit to ground does it set Cam sensor circuit low code? that would test both of the other circuits if so.
Let me know on this stuff, and have someone check Tech bulletins if you can.
justin
Interested in having you car wired? Drag car, street car, EFI swap?
PM for details
[Re: wldtm]
#1040480
07/27/11 12:35 AM
07/27/11 12:35 AM
HotRodDave
Kalispell Mt.
No codes come up with the sensor plugged in, I think it was P0340 when I unplugged it but it was definately a cam sensor code just not sure of the number. Of course the CEL is stuck on with it running. I tried the computer from a 99 intrepid with the same 2.7 and it runs the same way. The signal wire is not open or grounded, I checked with it unplugged from the ECU. I did not ask the other shop if they did anything to it yet, I don't think they did. The engine and trans bolts all look un-disturbed so I don't think there was any engine swap going on. I pulled the valve cover back off to make sure the tone wheel looked ok and it was real close to the sensor and no bends nicks dings... I had one from the old 99 intrepid engine and they looked identicle so I think it is ok. I checked TSBs on alldata and could find nothing. I even tried Google with no luck I will check the wires like you said in the morning. The one that went to the ECU ground I did check already and it was a good ground with the key on and nothing with the key off. One other thing that may be of use to know is when I start the engine then plug in the sensor it keeps running.
[Re: Scottmon]
#1040483
07/27/11 02:49 PM
07/27/11 02:49 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
Has the eng been replaced ?? Seen this before and the car had an eng replaced and even though they were the same eng the replaced eng had a different cam gear on it. Mopar went to a different cam gear on certain years with the slots at different spacing for the cam sensor and the PCM knows this. Basically they changed the cam sensor readings the PCM counts. We had this on a 2.7 eng a few years back. The cam sensor only needs to be looked at while cranking on some of the Mopar systems and once the eng starts the PCM dont look at the cam sensor anymore as once its running the PCM knows the firing order and when #1 is at comp once it looked at the cam gear. When it dont see the cam reading alot of times the PCM will just try firing orders (as cam sensor tells when #1 is on comp) until it gets it right and starts. I would look real close to see if the eng has been replaced with the wrong year eng. Basically Mopar used 2 types of ign-fuel circuits on the 2.7 and you have to have it right to work correct. We had to replace the eng in the car we had as even though it ran ok with the cam sensor unplugged it would eventually set a code and the car would not pass emissions like that. Ron
[Re: 383man]
#1040484
07/27/11 07:50 PM
07/27/11 07:50 PM
HotRodDave
Kalispell Mt.
So I just talked to the other shop, original engine... they did spark plugs and oil changes, she was religious about bringing it to them for every thing. They were aparently in the middle of an intersection, car dies and was towed to the other shop where they told them it needed a fuel pump then I go the call about a cheap car.
[Re: HotRodDave]
#1040485
07/29/11 12:10 AM
07/29/11 12:10 AM
HotRodDave
Kalispell Mt.
Could the timing chain have jumped and caused it to not start but still be able to run fine with the cam sensor unplugged?
[Re: wldtm]
#1040486
07/30/11 01:08 PM
07/30/11 01:08 PM
HotRodDave
Kalispell Mt.
wldtm I checked to see if it would set cam sensor low and high codes and it did both, testing just like you described. No TSBs in alldata or shopkey. Any one know how much compresion they usually have? I am getting 150 PSI across the board and wondering if the cam timing may be off one tooth even though it runs great with the sensor unplugged. Mabey if the computer sees them out of sync it cuts spark to avoid engine damage
[Re: HotRodDave]
#1040487
07/30/11 05:48 PM
07/30/11 05:48 PM
wldtm
Dayton, Ohio
then it sounds like all three wires and circuits check out ok. put a vacuum gauge on it and see what manifold vacuum is.
we has a 2.4 dohc in a stratus off 1 tooth and it ran like dog crap. had terrible vacuum, and it was only one tooth.
i think you are on to something....
PM for details
