Re: I need correct example of organisol texture [Re: UCUDANT] #1040337
08/02/11 10:41 PM
08/02/11 10:41 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Ucudant whose organsol is that?
Mike
Re: I need correct example of organisol texture [Re: DAYCLONA] #1040338
08/02/11 11:17 PM
08/02/11 11:17 PM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
I think this is it http://www.planetcolor.com/en/Products/~/media/Shared/Planet-Color/catalog.ashx about 15 pages in. He said the "reflective" has too much shine in daylight...I think he is right. We are using the regular black texture. And Dayclona I really want to see your 72 Cuda pics. Can you take them to get scanned somewhere pleeeeaaassseeee?
Re: I need correct example of organisol texture [Re: UCUDANT] #1040339
08/03/11 12:12 AM
08/03/11 12:12 AM
Shopping @ HoBo Fright
340SIX Offline
Doc Flappergas's Evil Twin
340SIX  Offline
How do you get price on it?
[img]https://i234.photobucket.com/albums/ee87/fast340six/sig%20pics/2840886-340SIX-1.jpg[/img]
VP of the MPM in New Orleans
73 Dart Sport 340/ 70 challenger vert. That may still get built, If I live long enough
Re: I need correct example of organisol texture [Re: 340SIX] #1040340
08/03/11 06:49 AM
08/03/11 06:49 AM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
340SIX I'd recommend calling your local paint houses to see who your closest distributors are.
I am pretty sure he said you mix in the texture powder yourself so you can experiment with the degree if texture desired. I had him describe how he shot it and it was straight forward off the directions reduced %50... so I guess you could vary that to test results as well
Re: I need correct example of organisol texture [Re: UCUDANT] #1040341
08/03/11 11:35 AM
08/03/11 11:35 AM
340SIX Offline
340SIX  Offline
What brand is the chip set from? etc #
Re: I need correct example of organisol texture [Re: 340SIX] #1040342
08/04/11 06:31 AM
08/04/11 06:31 AM
Answering the call of the wild
ThermoQuad Offline
ThermoQuad  Offline
The original texture additive for DDL9355 has been long gone for years. DDL means lacquer paint.
The current texture additive is smaller in size.
You can still buy DDL 9355 from the ppg store
DCC is a urethane paint and has no texture additive.
To the OP:
unless you have original paint the correct texture is made of unobtanium.
Since the tech archives suck here I will repost the painting process and a pic of real organisol that I sprayed about 2 years ago.
Organisol paint is never waxed.
Organisol Black Revised 11-2010
DDL9355
Disclaimer: I am no expert, but I am a painter and I have done my fair share of wresting with this paint. I have no experience putting DDL9355 over catalyzed paints as I was taught the arts when lacquer and enamel were all we had. When I paint it now it’s always on a primer or black lacquer surface The problem I see is this lacquer paint wants to be put in wet and thin which means a lot of solvent will try to bite into the enamel or urethane surface it’s being applied to.
You must lay the paint down wet or the texture will stand up instead of lay down and you will have an extremely rough finish that attracts everything.
Paint surfaces horizontal if possible
Use the slowest thinner and add some retarder as well if it is above 80 degrees. If possible use over black primer like DP90
Patience.
Allow surfaces to dry for at least 30 days before painting cover coats. This is important.
Works best painted over a black painted surface
Black DP90 is ok but black paint is better
Put 2 light but wet cover coats of semi gloss black lacquer over colored primers
Allow to dry at least 24 hrs or more before organosoling,
Use a gun with a big tip 1.6mm or larger
Cross coat the large area surfaces in 3 directions –eliminates streaking of texture diag first, short length, long length with large overlapping passes. It must go on wet!
Test spray before committing to car. Practice a little. Use SLOW thinner !!!! Lay on WET!
Patience!!!!! Thin 125%, 150% last 2 coats
After getting full coverage of texture typically 4 coats thin each progressive coat to 150% Use your judgment Think about 6 -8 coats.
Allow each coat to dry for at least 30 min.
Patience.
Texture must cover surface completely-there should be no gaps in the texture. The purpose of laying it on cross coating & wet is to get the texture to lay down flat.
Edge it in with a touch up gun first
Use fine line tape on all paint edge breaks
Do the bottom side of the hood first-part of your practice
Paint all other surfaces at the same time as the top side of the hood.
Across the tops of the fender & across the front header panel be sure to add 1-2 extra coats of Organosol to resist wear of the paint from stones, fender covers etc..
Re: I need correct example of organisol texture [Re: 340SIX] #1040343
08/04/11 08:47 AM
08/04/11 08:47 AM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
Planet color, PCR2 Black Texture Durable (High wear) See the Rugged Toned on page 15 here http://www.planetcolor.com/en/Products/~/media/Shared/Planet-Color/catalog.ashx not sure if they are owned by a larger parent paint company.
Re: I need correct example of organisol texture [Re: UCUDANT] #1040344
08/04/11 08:55 AM
08/04/11 08:55 AM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
Thanks Tom, this info should go in the tech archives. Roger Gibson is doing some testing with Eurothane products to try to duplicate the organisol finish. I had read an earlier post with your organisol painting tips but I needed a eurothane to be safe. Thanks to those in the know willing to take there time to share this info... Thank you Sir. My Car was shot yesterday.
Re: I need correct example of organisol texture [Re: UCUDANT] #1040345
08/04/11 09:17 AM
08/04/11 09:17 AM
Indiana, Just Off I-70
BradD Offline
BradD  Offline
Looks good from here!
Check out the Dorn's 69 Barracuda "Switchblade" in the Nov.2010 MCG
Check out the Dorn's refurbished 36 Ford in the Feb.2011 Street Rodder
Re: I need correct example of organisol texture [Re: BradD] #1040346
08/06/11 12:55 PM
08/06/11 12:55 PM
340SIX Offline
340SIX  Offline
sure looks nice
I figure that the paint was owned buy a larger paint company like SW or the paint Napa sells etc. thus me asking who
Thanks for the info so it could be had localy
Re: I need correct example of organisol texture [Re: 340SIX] #1040347
08/07/11 11:40 AM
08/07/11 11:40 AM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
Re: I need correct example of organisol texture [Re: UCUDANT] #1040348
08/07/11 08:10 PM
08/07/11 08:10 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Looks nice!
