Where is the best place to get beadlocks done? #1040196
07/25/11 11:47 PM
07/25/11 11:47 PM
Kalamazoo, MI
StrokedW7 Offline OP
Kalamazoo, MI
Steven M. Hamacher, CPA, MST
For ALL your tax, accounting, and payroll needs
www.Kalamazoo-CPA.com
Re: Where is the best place to get beadlocks done? [Re: StrokedW7] #1040197
07/25/11 11:54 PM
07/25/11 11:54 PM
Bama
Randy.. Offline
Randy..  Offline
Bama
Champion seems to be the most reasonable, but if $$$ is no object MacFab beadlocks.
Re: Where is the best place to get beadlocks done? [Re: Randy..] #1040198
07/25/11 11:57 PM
07/25/11 11:57 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
second that.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Where is the best place to get beadlocks done? [Re: 1967dartgt] #1040199
07/26/11 01:14 AM
07/26/11 01:14 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
What they said, Champion wheels...
Re: Where is the best place to get beadlocks done? [Re: Al_Alguire] #1040200
07/26/11 01:37 AM
07/26/11 01:37 AM
pacific northwest
Stroker Scamp Offline
pacific northwest
just for info sake, at et would one need beadlocks, seems to me some people just do them for looks rather than really needing them?? thoughts?
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: Where is the best place to get beadlocks done? [Re: StrokedW7] #1040201
07/26/11 01:41 AM
07/26/11 01:41 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I have a question about bead locks... do they run them
on both sides of the wheel... sure I've seen them on
the outer but never seen the inner to see if its there
Re: Where is the best place to get beadlocks done? [Re: Stroker Scamp] #1040202
07/26/11 01:42 AM
07/26/11 01:42 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Wel I only run bottom 8's and I dont have them. But that is a loaded question. As for sides, well both sides to realize all the benefits. If I were to do it it would be both sides. Otherwise I dont see any real point to it.
Re: Where is the best place to get beadlocks done? [Re: Stroker Scamp] #1040203
07/26/11 01:42 AM
07/26/11 01:42 AM
Bama
Randy.. Offline
Randy..  Offline
Bama
think it has more to do with tire stability and using wheels that are wider than there intended use 15x15/16x16 with a 33 10.5w or a 28 10.5 on a 12 in wheel, keeps the bead from breaking away at speed.
Re: Where is the best place to get beadlocks done? [Re: Randy..] #1040204
07/26/11 08:14 AM
07/26/11 08:14 AM
glendora, ca.
Deepockets Offline
Deepockets  Offline
glendora, ca.
on my duster i used the champion beadlock just on the outer and i screw the inner. it starts adding up in $ if you do both sides. also it added a considerable ammount of weight with just the one. i dont have any screws on the dart with a 29- 10.5w on it. with out any screews on them the move atleast 1/8" every hit. i need to doo something there. if your going to go double, save your lunch monney and get the welds.
Re: Where is the best place to get beadlocks done? [Re: Deepockets] #1040205
07/26/11 09:44 AM
07/26/11 09:44 AM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
Weld does it and runs a special once or twice a year. Talk to holly
Re: Where is the best place to get beadlocks done? [Re: joshking440] #1040206
07/26/11 10:38 AM
07/26/11 10:38 AM
Blue Ridge, VA
Plumb Wired Offline
Plumb Wired  Offline
Blue Ridge, VA
Some can't be beadlocked on the inside because of the backspacing causing interference with calipers if you run rear disc.
http://www.redsbeadlock.com/
http://beadlockconversions.com/
http://www.cwibeadlock.com/
Like mentioned above Champion is the most reasonable but for us on the east coast shipping cost and time come into play.
Mike Gray
RIP Monte Smith
aka: OutlawFish
'98 Bickel Dodge Dakota PST
Re: Where is the best place to get beadlocks done? [Re: joshking440] #1040207
07/26/11 10:43 AM
07/26/11 10:43 AM
North Cackilacky
sdaurity Offline
sdaurity  Offline
North Cackilacky
Tommy/Mac Fab is the best and his shop is 1/2 of a mile from me and I do tons of work on all his cars. They are the best by far.
One day I will have something cool here.
Re: Where is the best place to get beadlocks done? [Re: sdaurity] #1040208
07/26/11 11:08 AM
07/26/11 11:08 AM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
Liners are much lighter. But, I don't know how many sizes they have. Probably nothing for 10.5.
I personally can't see any point just putting them on the outside other than they look trick.
We just did a set of tires with trim adhesive on a new set of Holeshots. The owner was resistant about drilling his brand new wheels. I expect it is really going to be a pain getting them off without somekind of solvent.
You can run a lower pressure with beadlocks. Larry Perkins made the switch on his Pro Comp car a few years back and said it really helped with wheel speed and getting up on the tire. Would have liked to tried it but, the cost was too much for a trial for me.
Leon
Re: Where is the best place to get beadlocks done? [Re: Deepockets] #1040209
07/26/11 01:51 PM
07/26/11 01:51 PM
Kalamazoo, MI
Kalamazoo, MI
That is what I am going to do as well (i.e. beadlocks on outside and screws on the inside). My car isnt fast enough to need both sides done. So there is no reason to spend the additional money. Now that I have Lenco in the car, I am going to need to do something. I really do not like the look of screws, so I thought I would just get the outsides beadlocked. My wheels are Bogarts and I just spoke to a guy there and they said they could take my wheels and add the beadlocks for $245 each.
Re: Where is the best place to get beadlocks done? [Re: StrokedW7] #1040210
07/26/11 02:32 PM
07/26/11 02:32 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
Weld will not do just the outside, and when they run the deal it is 400 per wheel double beadlocks if I rememeber correctly
Re: Where is the best place to get beadlocks done? [Re: StrokedW7] #1040211
07/26/11 03:06 PM
07/26/11 03:06 PM
nc
cold85 Offline
cold85  Offline
nc
mac fab hands down!
