Re: {{{{{{ GOT VIDEO }}}}}} [Re: quick77rt ] #1040165
07/27/11 06:40 PM
07/27/11 06:40 PM
scratchnfotraction Offline
Re: {{{{{{ GOT VIDEO }}}}}} [Re: scratchnfotraction] #1040166
07/27/11 07:08 PM
07/27/11 07:08 PM
Ohio
Chad Bittle Offline
Chad Bittle  Offline
Ohio
Wanna sell that black D150 in the background for cheap?
Re: {{{{{{ GOT VIDEO }}}}}} [Re: Chad Bittle] #1040167
07/27/11 07:19 PM
07/27/11 07:19 PM
Finally a HUSKER again
Moparnut426 Online content
Moparnut426  Online Content
Nice!!
I like that ya have grade 8 bolts holding the guage pannel on. Thats just incase the torque spins her around huh??
Sounded REAL good!!
Kasey
Re: {{{{{{ GOT VIDEO }}}}}} [Re: Chad Bittle] #1040168
07/27/11 07:26 PM
07/27/11 07:26 PM
Lehigh Acres, Florida
rickstershemi Offline OP
Nope
Rickster
Re: {{{{{{ GOT VIDEO }}}}}} [Re: Moparnut426] #1040169
07/27/11 07:29 PM
07/27/11 07:29 PM
Nice!!
Sounded REAL good!!
Kasey
Thanks and that's funny...lol Whatever's lying around handy...that's how the stand got built also...pulled from inventory....yeah that sounds better
Rickster
Re: {{{{{{ IT'S FINALLY ALIVE }}}}}} [Re: rickstershemi] #1040170
07/28/11 09:46 AM
07/28/11 09:46 AM
acworth / N. georgia - south e...
cheapstreetdustr Offline
your gonna want to source a distributor that has mechanical/vacume advance...Especially with a stick..and the concern about detination..
the only way to tame it is going to be with timing that moves as your rpm/vacume changes...
especially lugging a stickshift on normal road driving/parkinglot/.. it will detinate if the timing and or dist. is fixed.. IMHO.
great to hear about the progress...
cheapst
Jim maybe you missed that it has an MSD E-Curve with over 100 different mech/vac advance curves.....being a stick car I will most likely pick a slow curve that's all in by say 3000rpm.....one thing nice about a clutch it's like an adjustable converter...leave where you want....lol
Pics and vid to follow
Rickster
Oh!! even better...that msd set up should help you find the right curve..
We did a rat rod (guy down the street) he had flat deck 360 with eddies.connected to a newprocess 5spd.
the car was light...(framerails and cab type deal)
it had a 3.23 gear..with a 31" rear tire.
I drove that car alot..and on pumpgas it would ping..quite a bit at low lugged rpm..like pulling in and or out of parking lots..or if you made a turn..in the wrong gear....it would ping..
Otherwise...It ran fine if you didnt lugg it..
Even at highway speed..when you tipped into it.
no pinging at all..and from a stop normal driving or leaving hard...no detination...
was alot of fun to drive on the street...that 3.23 gear was neat..sort of like a powerglide..
The torque multiplication ..felt like a fluid or hydraulic application of power in the low gears..
cheapst
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured
[image][/image]
