{{{{{{ IT'S FINALLY ALIVE }}}}}} VIDEO ADDED....!!!!! #1040145
07/25/11 11:02 PM
07/25/11 11:02 PM
Lehigh Acres, Florida
rickstershemi Offline OP
Yep....fired up the 408 today on the test stand I built and it runs great....no leaks, fairly aggressive idle and snappy as all get-out....oh yeah love the tunnel ram and 500 avs's
Now....after a good 20 minute run-in @ 2000 rpm and a few heat cycles....i ck'd cranking compression and all holes are between 205 - 210
Best guess on compression is somewhere around 10.5 - 11.1 flat top icons / 5cc reliefs @ zero deck.....J Heads 2.02/1.60 midly massaged that have been decked a few times throughout their life and uncertain on volume...????
Erson Cam: Intake 312/504 Exhaust 320/517 110+4 Gross Lift: Intake 335/248 @.050 Exhaust 345/256 @.050
Timing is locked out for now at 32* w/10* start retard, the MSD E-Curve works flawlessly and not a hint of detonation on 93 pump swill with zero load of course.....will it live on 93 on the street....?????
Keep in mind the 64 Valiant will probably end up weighing at close to 3000# 4-speed and 3,23's w/27" tires
Engine builder seems to feel it will be A/OK.....what are your thoughts ??????
Rickster
Re: {{{{{{ IT'S FINALLY ALIVE }}}}}} [Re: rickstershemi] #1040146
07/25/11 11:08 PM
07/25/11 11:08 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Cool... I think your going to be to high on compression
with over 200..... JMO.... assuming this is a street engine
Re: {{{{{{ IT'S FINALLY ALIVE }}}}}} [Re: rickstershemi] #1040147
07/25/11 11:09 PM
07/25/11 11:09 PM
MI
68shifter Offline
68shifter  Offline
MI
Engine will be fine!
The rear tires and your left leg on the other hand
Great build. Keep the updates comin.
68' Barracuda (4 speed) 64' Savoy (4 speed) 65' Satellite (girl tranny)
Re: {{{{{{ IT'S FINALLY ALIVE }}}}}} [Re: rickstershemi] #1040148
07/25/11 11:13 PM
07/25/11 11:13 PM
detroit, mi
POS Dakota Offline
POS Dakota  Offline
detroit, mi
I agree...although in the light car it may be ok who knows?
If not, you could always go with some more cam to tone it down.
If you get away with it, I really woudln't be surprised though.
I know someone with a 390 and just about the same cranking compression and he ran fine on the street in a heavy dakota 4x4...
Congrats Rick!
SO how about a vid??????
Re: {{{{{{ IT'S FINALLY ALIVE }}}}}} [Re: POS Dakota] #1040149
07/25/11 11:18 PM
07/25/11 11:18 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Congrats... post up some pics please
Re: {{{{{{ IT'S FINALLY ALIVE }}}}}} [Re: Bob_Coomer] #1040150
07/25/11 11:20 PM
07/25/11 11:20 PM
Took a video Bob but it was windy and sounded like crap so I dumped it....will try and get one posted up tomorrow
Rickster
Re: {{{{{{ IT'S FINALLY ALIVE }}}}}} [Re: rickstershemi] #1040151
07/26/11 12:45 AM
07/26/11 12:45 AM
Toronto
mshred Offline
mshred  Offline
Toronto
congrats rick! I can't really offer any insight on whether it will run pump gas or not, but im sure it felt great to have it running with no problems, and your probably that much more hungry to get it in the car and beat on it!
and by the way...video please!
Re: {{{{{{ IT'S FINALLY ALIVE }}}}}} [Re: rickstershemi] #1040152
07/26/11 01:13 AM
07/26/11 01:13 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Don`t ya just love firing up a fresh mill providing nothing goes wrong? Enjoy.............
Re: {{{{{{ IT'S FINALLY ALIVE }}}}}} [Re: Thumperdart] #1040153
07/26/11 09:01 AM
07/26/11 09:01 AM
acworth / N. georgia - south e...
cheapstreetdustr Offline
your gonna want to source a distributor that has mechanical/vacume advance...Especially with a stick..and the concern about detination..
the only way to tame it is going to be with timing that moves as your rpm/vacume changes...
especially lugging a stickshift on normal road driving/parkinglot/.. it will detinate if the timing and or dist. is fixed.. IMHO.
great to hear about the progress...
cheapst
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured
[image][/image]
Re: {{{{{{ IT'S FINALLY ALIVE }}}}}} [Re: cheapstreetdustr] #1040154
07/26/11 09:09 AM
07/26/11 09:09 AM
cheapst
Jim maybe you missed that it has an MSD E-Curve with over 100 different mech/vac advance curves.....being a stick car I will most likely pick a slow curve that's all in by say 3000rpm.....one thing nice about a clutch it's like an adjustable converter...leave where you want....lol
Pics and vid to follow
Rickster
Re: {{{{{{ IT'S FINALLY ALIVE }}}}}} [Re: rickstershemi] #1040155
07/26/11 09:14 AM
07/26/11 09:14 AM
tboomer Online work
tboomer  Online Work
Good luck,Rick!
Re: {{{{{{ IT'S FINALLY ALIVE }}}}}} [Re: tboomer] #1040156
07/26/11 12:41 PM
07/26/11 12:41 PM
detroit, mi
POS Dakota Offline
POS Dakota  Offline
detroit, mi
Re: {{{{{{ IT'S FINALLY ALIVE }}}}}} [Re: POS Dakota] #1040157
07/26/11 12:49 PM
07/26/11 12:49 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
The only thing I would look into is a set of 3.54 or 3.73 gears.......that's it!
Enjoy!
Re: {{{{{{ IT'S FINALLY ALIVE }}}}}} [Re: rickstershemi] #1040158
07/26/11 12:59 PM
07/26/11 12:59 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I'll be surprised if it runs on 93 without detonating. It should be a fun car .
Re: {{{{{{ IT'S FINALLY ALIVE }}}}}} [Re: justinp61] #1040159
07/26/11 01:53 PM
07/26/11 01:53 PM
detroit, mi
POS Dakota Offline
POS Dakota  Offline
detroit, mi
Like I said earlier...I have a friend with a 390 cid stroked iron headed magnum engine with 11:1 compression and a 236/242 @ .050 cam. He ran 93 in it, in a heavy azz dakota 4x4...I am thinking he might get away with it. Now the 390 was a closed chamber and rick's using j heads....how much difference that will make I dunno...but I guess there's only one way to find out!
Re: {{{{{{ IT'S FINALLY ALIVE }}}}}} [Re: POS Dakota] #1040160
07/26/11 07:05 PM
07/26/11 07:05 PM
scratchnfotraction Offline
Re: {{{{{{ GOT VIDEO }}}}}} [Re: scratchnfotraction] #1040161
07/26/11 09:56 PM
07/26/11 09:56 PM
Ok.....here's a short video....don't expect much....lol It's running pig rich....need to install a regulator as the pressure is at 9lbs and the AVS's like 5.5 - 6lbs max.
Rickster
Re: {{{{{{ GOT VIDEO }}}}}} [Re: rickstershemi] #1040162
07/26/11 11:22 PM
07/26/11 11:22 PM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
Rick, nice job! That car should be a hoot on the street! Start turning those wrenches, and you can be driving it this weekend!
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: {{{{{{ GOT VIDEO }}}}}} [Re: DusterDave] #1040163
07/27/11 09:09 AM
07/27/11 09:09 AM
Thanks to all for your thoughts and comments.....I guess we will have to wait and see when she hits the streets....I'm on the fence but do have faith in Mike's judgement when it comes to engines
If it ends up requiring a blend it's not like it's going to be a daily driver....now just to hit the lotto and get the car finished
Can't wait to take her for a spin
Rickster
Re: {{{{{{ GOT VIDEO }}}}}} [Re: rickstershemi] #1040164
07/27/11 11:08 AM
07/27/11 11:08 AM
Q
quick77rt Offline
Parts Problem
quick77rt  Offline
Parts Problem
Q
Very very nice, a smoke and a beer.....motors cool as well
