{{{{{{ IT'S FINALLY ALIVE }}}}}} VIDEO ADDED....!!!!!
#1040145
07/25/11 11:02 PM
07/25/11 11:02 PM
Posts: 9,366 Lehigh Acres, Florida
rickstershemi
Yep....fired up the 408 today on the test stand I built and it runs great....no leaks, fairly aggressive idle and snappy as all get-out....oh yeah love the tunnel ram and 500 avs's ![](/ubbthreads/images/graemlins/boogie.gif) Now....after a good 20 minute run-in @ 2000 rpm and a few heat cycles....i ck'd cranking compression and all holes are between 205 - 210 ![](/ubbthreads/images/graemlins/shock.gif) Best guess on compression is somewhere around 10.5 - 11.1 flat top icons / 5cc reliefs @ zero deck.....J Heads 2.02/1.60 midly massaged that have been decked a few times throughout their life and uncertain on volume...???? Erson Cam: Intake 312/504 Exhaust 320/517 110+4 Gross Lift: Intake 335/248 @.050 Exhaust 345/256 @.050 Timing is locked out for now at 32* w/10* start retard, the MSD E-Curve works flawlessly and not a hint of detonation on 93 pump swill with zero load of course.....will it live on 93 on the street....????? Keep in mind the 64 Valiant will probably end up weighing at close to 3000# 4-speed and 3,23's w/27" tires ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif) Engine builder seems to feel it will be A/OK.....what are your thoughts ?????? Rickster
Re: {{{{{{ IT'S FINALLY ALIVE }}}}}}
[Re: rickstershemi]
#1040147
07/25/11 11:09 PM
07/25/11 11:09 PM
Posts: 1,169 MI
68shifter
MI
Engine will be fine! The rear tires and your left leg on the other hand ![](/ubbthreads/images/graemlins/drive.gif) Great build. Keep the updates comin.
68' Barracuda (4 speed)
64' Savoy (4 speed)
65' Satellite (girl tranny)
[Re: rickstershemi]
#1040148
07/25/11 11:13 PM
07/25/11 11:13 PM
Posts: 1,074 detroit, mi
POS Dakota
detroit, mi
I agree...although in the light car it may be ok who knows? If not, you could always go with some more cam to tone it down. If you get away with it, I really woudln't be surprised though. I know someone with a 390 and just about the same cranking compression and he ran fine on the street in a heavy dakota 4x4... Congrats Rick! ![](/ubbthreads/images/graemlins/thumbs.gif) SO how about a vid?????? ![](/ubbthreads/images/graemlins/whistling.gif)
[Re: Bob_Coomer]
#1040150
07/25/11 11:20 PM
07/25/11 11:20 PM
rickstershemi
Congrats... post up some pics please
Took a video Bob but it was windy and sounded like crap so I dumped it....will try and get one posted up tomorrow ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif)
Rickster
[Re: Thumperdart]
#1040153
07/26/11 09:01 AM
07/26/11 09:01 AM
Posts: 6,257 acworth / N. georgia - south e...
cheapstreetdustr
your gonna want to source a distributor that has mechanical/vacume advance...Especially with a stick..and the concern about detination.. the only way to tame it is going to be with timing that moves as your rpm/vacume changes... especially lugging a stickshift on normal road driving/parkinglot/.. it will detinate if the timing and or dist. is fixed.. IMHO. great to hear about the progress... ![](/ubbthreads/images/graemlins/thumbs.gif) cheapst
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured [image][/image]
[Re: cheapstreetdustr]
#1040154
07/26/11 09:09 AM
07/26/11 09:09 AM
rickstershemi
Jim maybe you missed that it has an MSD E-Curve with over 100 different mech/vac advance curves.....being a stick car I will most likely pick a slow curve that's all in by say 3000rpm.....one thing nice about a clutch it's like an adjustable converter...leave where you want....lol
Pics and vid to follow
Rickster
[Re: rickstershemi]
#1040158
07/26/11 12:59 PM
07/26/11 12:59 PM
Posts: 11,686 W. Kentucky
justinp61
W. Kentucky
I'll be surprised if it runs on 93 without detonating. It should be a fun car .
[Re: justinp61]
#1040159
07/26/11 01:53 PM
07/26/11 01:53 PM
POS Dakota
detroit, mi
Like I said earlier...I have a friend with a 390 cid stroked iron headed magnum engine with 11:1 compression and a 236/242 @ .050 cam. He ran 93 in it, in a heavy azz dakota 4x4...I am thinking he might get away with it. Now the 390 was a closed chamber and rick's using j heads....how much difference that will make I dunno...but I guess there's only one way to find out!
Re: {{{{{{ GOT VIDEO }}}}}}
[Re: rickstershemi]
#1040162
07/26/11 11:22 PM
07/26/11 11:22 PM
Posts: 1,845 Tampa
DusterDave
Tampa
Rick, nice job! That car should be a hoot on the street! Start turning those wrenches, and you can be driving it this weekend!
Gone to the dark side with an LS3 powered '57 Chevy 210
[Re: DusterDave]
#1040163
07/27/11 09:09 AM
07/27/11 09:09 AM
rickstershemi
Thanks to all for your thoughts and comments.....I guess we will have to wait and see when she hits the streets....I'm on the fence but do have faith in Mike's judgement when it comes to engines ![](/ubbthreads/images/graemlins/luck.gif) If it ends up requiring a blend it's not like it's going to be a daily driver....now just to hit the lotto and get the car finished ![](/ubbthreads/images/graemlins/hammer.gif) Can't wait to take her for a spin ![](/ubbthreads/images/graemlins/drive.gif) Rickster
