Re: Putting spring on A body hood hinge
[Re: Dart6pak]
#1039752
07/25/11 08:12 PM
07/25/11 08:12 PM
Posts: 257 albemarle, NC
dusterbd13
albemarle, NC
I had one of my springs pop off on a hood hinge --it is still attached in the center only came off the peg and sprung open.
I know I can get to it through the access panel.
Is there any trick to putting this back on.
yup. tricks to remove the hinge assembly from the car (come out through the inner gender splash shield). then you have to preload the spring about 1 full turn
hope that helps michael
[Re: west]
#1039753
07/25/11 09:32 PM
07/25/11 09:32 PM
Posts: 1,216 Under My Car
Mopar_Country
Under My Car
I'm not sure it will be easy with the fender on but I would use vise grips and leather gloves
Yup, you can access it with the splash shield removed. Get one time around on the coil, get it over the tab, hope it don't do it again.
I had to do the same thing, it can be done but it's a pain. Mine did it 3 times. After the last one I got the coil on there and zapped the end of the tab on the corner with my welder, enough to create a stop, just to pin it on.
