Re: Drag Week Duster
[Re: 69B3GT]
#1039545
07/25/11 07:55 AM
07/25/11 07:55 AM
Posts: 1,169 MI
68shifter
MI
Wow! That's pretty awesome. Can you give some more info on the build etc... Thanks, looks real good.
68' Barracuda (4 speed)
64' Savoy (4 speed)
65' Satellite (girl tranny)
[Re: DusterDj]
#1039549
07/25/11 10:40 AM
07/25/11 10:40 AM
Posts: 52,972 Romeo MI
MR_P_BODY
DJ if I recall you were going to pull the blowers to run the street.... is there a way you can pull a idler gear and leave them on there
[Re: MR_P_BODY]
#1039551
07/25/11 11:17 AM
07/25/11 11:17 AM
Posts: 324 Oklahoma City, Oklahoma
DusterDj
Provisions have already been made to do exactly that. Trying to make here as efficient as possible... But great minds think alike man...
[Re: PC-CHARGER]
#1039552
07/25/11 11:20 AM
07/25/11 11:20 AM
DusterDj
With the compression you will likely be running with the Prochargers, I'm guessing valve clearance is not an issue especially considering the position of the valve reliefs in the pistons and the heads you are using?
Correct, anything I have missed Steve Morris, the procharged guru, will catch. Should have some more updates out to ya guys here soon...
[Re: Jeff_383]
#1039555
07/25/11 01:56 PM
07/25/11 01:56 PM
MR_P_BODY
Cool car, hope you give'ema run. I too dug the old paint job on it!
The bad part about the drag week cars is that you cant advertise on it..... at least this was my understanding
[Re: Bigcube]
#1039560
07/26/11 12:21 AM
07/26/11 12:21 AM
MR_P_BODY
Nice job! Chassis looks great, How tall of tire? I'd like to see that thing 1-2" lower in the back... but I'm sure it will settle when you start adding everything else... Which B1's are they? How many cubes? How much boost?
Jim ... if I recall he's running B1 M/C heads
