hey guys, is there an adjustment on the ignition switch on a 75 duster, maybe to the stop when the key springs back to the accessory position after starting? I just got the duster started up, after a new engine and all new wiring, and if I don't keep the key barely turned to the right after the engine starts, my msd box will lose power, and the engine will shut off. If I have the key turned over to the first accessory stage, the msd box is not lit like it should be, but if I barely turn it farther like I am going to start the car, then the light will come on. I thought maybe you have to adjust the switch so that it is at the proper location when the accessories are on. Any thoughts?
Thanks,
Will
