Hemi installation in a b-body #1038974
07/24/11 01:40 PM
07/24/11 01:40 PM
Pennsylvania
hemi67 Offline OP
hemi67  Offline OP
Pennsylvania
getting ready to install my hemi in a 67 B- body from the bottom. Never done this before and it looks like the shaft from the steering column is in the way of the driver side valve cover as the car is being lowered onto the k frame. Does the steering column have to be removed to do this, or will removing the driver side valve cover give me enough clearance? It is a stock hemi with stock heads and valve covers and also it is a manual steering car.
thanks for your help.
Re: Hemi installation in a b-body [Re: hemi67] #1038975
07/24/11 01:45 PM
07/24/11 01:45 PM
Spring Valley ,Ca.
moparsquid Offline
moparsquid  Offline
Spring Valley ,Ca.
Id say pull the s-shaft its ony a few bolts.
Re: Hemi installation in a b-body [Re: moparsquid] #1038976
07/24/11 02:28 PM
07/24/11 02:28 PM
Virginia
HemiStan Offline
HemiStan  Offline
Virginia
I pull the steering column on mine. I leave the dip stick tube in place but I do take off the RH valve cover.
Stan
Re: Hemi installation in a b-body [Re: HemiStan] #1038977
07/24/11 02:36 PM
07/24/11 02:36 PM
Pennsylvania
hemi67 Offline OP
hemi67  Offline OP
Pennsylvania
Thanks for your help. I think thats good advice. looks like the right valve cover is too close to the brake line. I will pull the steering column and the rh valve cover.
thanks again.
