AndyF Denso bracket kit question #1038970
07/24/11 01:34 PM
07/24/11 01:34 PM
Downtown Roebuck Ont
Twostick Offline OP
Still wishing...
Twostick  Offline OP
Still wishing...
Is there any other Denso alternator besides the Toyota that will work with these brackets?
Kevin
Re: AndyF Denso bracket kit question [Re: Twostick] #1038971
07/24/11 10:15 PM
07/24/11 10:15 PM
Twostick Offline OP
Still wishing...
Twostick  Offline OP
Still wishing...
Kevin
Anybody??
Re: AndyF Denso bracket kit question [Re: Twostick] #1038972
07/24/11 10:18 PM
07/24/11 10:18 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Hi Kevin
I believe his kit was designed for the Powermaster Denso alternator You can drop Andy a PM to double check but I have one of his kits for the AR motorplate low mount and had to slightly modify it to use a stock 91 Yota truck alternator.I know the Powermaster is slightly smaller than the unit I am using.
Gus
64 Plymouth Savoy
Dana 60
Re: AndyF Denso bracket kit question [Re: fourgearsavoy] #1038973
07/24/11 10:29 PM
07/24/11 10:29 PM
Twostick Offline OP
Still wishing...
Twostick  Offline OP
Still wishing...
Hey Gus!
The kit I have says it will work with the late 80's 4Runner or truck 60 amp alt. I just wondered if the mounting points were the same on say a Mazda or any other donor vehicle with an ND alt in the bone yard.
Kevin
