stamped rocker question b engine(help)
#1038748
07/23/11 10:39 PM
07/23/11 10:39 PM
Posts: 576 Hr up from KCK
451 D*O*D*G*E
Hr up from KCK
I ordered new stamped rockers for my 451 through summit,MP units 8 ending number *****76 8 ending *****77.All of them appear to be the same to me!I was capping off my engine and stalled out on this.All the (right) valves stems line up with the rockers and the(left) are off center of the stem. I havnt disassembled the pass side shafts yet but even with all 16 new ones laid out the push rod cup looks to be to the same side on all rockers,while my old ones the cups appear to well,right as in proper relation per two for each set. Is it the heat or do i have 16 right side rocker arms even though 8 of them were packaged 77 while the other 8 76. ALl of them have a 4 stamped on them, Any ideas greatly appreciated!!!!
1970 Challenger R/T clone
2010 Dodge Journey R/T black,awd,
Re: stamped rocker question b engine(help)
[Re: Randy..]
#1038751
07/24/11 01:29 AM
07/24/11 01:29 AM
Posts: 75,094 A Banana Republic near you.
JohnRR
return them and get a good adjustable set,
DING DING DING .... WINNER ... I worked on a 440 with those rockers , should have just ponied up for adjustable rockers by the time all was said and done .
[Re: JohnRR]
#1038752
07/24/11 02:21 AM
07/24/11 02:21 AM
451 D*O*D*G*E
Hr up from KCK
Well i guess i must be right they are mislabeled,will summit take them back they are all out of the packages???
[Re: 451 D*O*D*G*E]
#1038753
07/24/11 02:56 AM
07/24/11 02:56 AM
Posts: 6,906 IL, Aurora
ademon
IL, Aurora
Summit will, your lucky you ordered from them!
[Re: JoesMopar]
#1038755
07/24/11 10:09 AM
07/24/11 10:09 AM
JohnRR
This has nothing to do with "you should have got adjustable rockers"....
They're labeled wrong....the same thing happened to me. Call Mopar Performance and they will get you the correct "lefts". Send them you're complete set with your receipt from Summit. Better hurry....as they don't make them anymore.
He should have gotten adjustable rockers, the clearance between those rockers is going to be as much as .050, if he has a Comp XE cam it's going to make a racket ...
[Re: JohnRR]
#1038756
07/24/11 11:53 AM
07/24/11 11:53 AM
451 D*O*D*G*E
Hr up from KCK
I have the Mopar .509 cam.Man i just dont have 5-600 dollars for new push rods and the adjustable rockers Probably need new shafts with the new rockers,,700 bucks for a street car valvetrain.I dont havea problem with that but need some bread.Do the make a standard low deck ball/cup push rod or do i have to measure even for this hydraulic cam? Thanks for the help.
[Re: 451 D*O*D*G*E]
#1038759
07/24/11 12:39 PM
07/24/11 12:39 PM
Posts: 6,569 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
You should ALWAYS measure them. Then there is no guessing what your lifter preload is. Get a checking push rod and check them like JohnRR said. If they're too long you get too much lifter preload and they'll hang a valve open at high rpm.
Those rockers will work OK for that cam IMHO. I'm using them on my 493 with the same cam with no problems. Just send the wrong ones back to Summit and they'll make it right.
Kevin
[Re: Twostick]
#1038760
07/24/11 01:00 PM
07/24/11 01:00 PM
451 D*O*D*G*E
Hr up from KCK
Thanks John for the preload specs.I will send them back. Seems like this from Hughes is no more than the iron adjustables after shafts and hardware what you guys think of this from Hughes. rocker kit I have iron heads.I can "swipe" the card because i need to keep moving to get this thing back on the road. Can i get everything for 500? I dont know the deck height.Or heads.Used a stock FelPro gasket.
[Re: 451 D*O*D*G*E]
#1038763
07/24/11 01:21 PM
07/24/11 01:21 PM
Twostick
Still wishing...
Still wishing...
Thanks i'll try Summit first they have been lightning fast on shipping but thanks for your help i'll see what Summit does for me.Or is the reason to call MP to make sure this doesnt happen a second time?
I would be really surprised if MP would exchange parts that you bought from Summit. Assuming that they would it's still no guarantee because they were the ones who packaged them wrong in the first place.
Just call Summit and explain the deal and see if they can verify the correct parts before they ship them the second time. It's not the first time they have had it happen I'm sure.
Kevin
[Re: 451 D*O*D*G*E]
#1038765
07/24/11 01:44 PM
07/24/11 01:44 PM
451 D*O*D*G*E
Hr up from KCK
I have 300lbs open springs is that really ok for stamped rockers????
[Re: Twostick]
#1038766
07/24/11 03:04 PM
07/24/11 03:04 PM
Posts: 2,782 USA
JoesMopar
USA
Kevin
Well then prepare to be really suprised....because as I mentioned earlier I had the SAME problem and MP took care of it without any hassle. Actually, Summit was more suspicious than MP. Had I sent them back to Summit, you could be sure they would have just sent me more mislabled rockers. All you have to do is contact MP, explain the issue, then send them your COMPLETE set with the receipt that you did purchase them from Summit, and they will overnight you a new set as soon as they have the correct parts. When I purchased mine from Summit, they came in bags with a generic paper label on them....when MP sent me the correct ones, they came in individual small boxes.
I have these same rockers using an XE268 cam and no noise issues.
[Re: 451 D*O*D*G*E]
#1038767
07/24/11 07:59 PM
07/24/11 07:59 PM
Posts: 1,285 Pacific NW USA
CompSyn
Pacific NW USA
The factory stamped steel rocker arms are light weight, strong, don't have any moving parts to go bad, and don't have any fitment issues under stock valve covers. They're great for a street car.
Just get one adjustable push rod length checking tool and measure for the exact length push rod you need for the correct lifter pre-load. Then order a set of custom length push rods from Smith Bros.
You can also get special shims that go under the rocker shafts to make small corrections as well.
