Pulley Alignment
#1038317
07/23/11 12:39 AM
07/23/11 12:39 AM
Posts: 3,842 N.E. Ohio
6bblFLASH
N.E. Ohio
How critical/what can you get away with as far as pulley alignment?
10-rib belt,NOT cog. From crank to blower its off .300. Was`nt a problem with the 383 in car,but checking on engine stand is where I found it. WAS working that way,what little I used it.
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas 9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ! 2013 StickShift Challenge Winner@ Mopar Nationals!
Re: Pulley Alignment
[Re: 6bblFLASH]
#1038319
08/07/11 05:05 AM
08/07/11 05:05 AM
Posts: 1,445 Sterling Heights, Michigan 483...
daniel_depetro
I say make a new crank pulley spacer.
On our B&M supercharged Dart the alignment wasn't off anywhere near that much and it would cause the belt to walk off the pulley and then shred.
1969 Dodge Super Bee A12 (440 Six Pack, 4-speed, Dana 60 4.10)
1972 Plymouth Road Runner (400, 4-speed, 8.75" 3.23)
1974 Plymouth Duster 360 (360, 4-speed, 8.75" 3.23)
