This Crower solid flat cam came in a motor I bought. What do I all need for it to run decent in a 440? What CR, TQ converter, rear gears?
It is not for a all out race car but a Rat Rod truck (2200lbs). I want it to sound good, run good, and not fall on its face! All out HP not a top priority. It will have lake style headers and a sheet metal tunnel ram with two Predator carbs.
Cam Card Info
Intake Duration 304 lift .548 lash hot .022
Exhaust Duration 310 lift .557 lash hot .024
This info is for degreeing cam only. Correct only at .05" tappet lift
Intake opens at 20.0 BTDC
Intake closes at 52.0 ABDC
Exhaust opens at 62.0 BBDC
Exhaust closes at 14.0 ATDC
Lobe Sep 110
Duration at .05"
Intake 251
Exhaust 255
Lobe lift
Intake .365
Exhaust .371
Just trying to deside if I should use it or dump it and buy something better?
