Re: Badly Stamped VIN Sequence #'s On Engines & Transmision [Re: 72 RR DUDE] #1038111
09/17/11 01:58 PM
09/17/11 01:58 PM
Spokane Washington
ScottSmith_Harms Offline OP
Mr Wizzard
Mr Wizzard
Spokane Washington
On your 72 It's likely original and never got stamped, I've seen a few examples of VIN stamps that got missed on either the trans or engine, seems most common with LA.built cars, especially really sloppy stamps. If yours is a warranty block it will provide other clues and was almost certainly installed somewhere other than the production line. Post some good pictures of the front and sides of the block if you can.
Re: Badly Stamped VIN Sequence #'s On Engines & Transmision #1038112
09/17/11 04:22 PM
09/17/11 04:22 PM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
My '71 Barracuda, despite being all orignal paint and never having been apart, had no VIN anywhere on the core support.
i have a 71 barracuda that there are NO VIN #'s on the core support OR the cowl.
the car didn't have a engine, trans, fender tag, or build sheet when i bought it. the car was also in a fender bender so the upper radiator support was replaced with a used one by me.
the car will be a modern cruiser so numbers aren't important to me.
perception is 90% of reality
Re: Badly Stamped VIN Sequence #'s On Engines & Transmision [Re: Mr T2U] #1038113
09/17/11 07:04 PM
09/17/11 07:04 PM
South, FL
cudaized Offline
cudaized  Offline
South, FL
Years ago, I looked at a 70 hemicuda. It had the same. No numbers stamped on the cowl nor radiator support. No Data Plate. Did not even have the holes drilled.
After some research, it turned out to be a Body In White from the factory. Some how, some time, it recieved a V.I.N. plate.
Re: Badly Stamped VIN Sequence #'s On Engines & Transmision [Re: cudaized] #1038114
09/17/11 07:15 PM
09/17/11 07:15 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
i thought the numbers stamped on the core support and the sail panel were the build sheet production number--that is why the build sheet is important--you cant see the sail part unless you pull the rear window out---bob
Re: Badly Stamped VIN Sequence #'s On Engines & Transmision [Re: ScottSmith_Harms] #1038115
09/18/11 08:13 AM
09/18/11 08:13 AM
Hamburg, Pa.
72 RR DUDE Offline
72 RR DUDE  Offline
Hamburg, Pa.
Scott
Do you want pictures of the both sides of the block and and do you want the hole side. Also do you want the whole front? What are some other ways you can tell if it is a warranty block?
Re: Badly Stamped VIN Sequence #'s On Engines & Transmision [Re: 72 RR DUDE] #1038116
09/18/11 11:32 AM
09/18/11 11:32 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Both entire sides and the entire front (must be clear non blurred pics). I won't say all the details but I'll point some out if I see any indicators.
Re: Badly Stamped VIN Sequence #'s On Engines & Transmision [Re: ScottSmith_Harms] #1038117
09/23/11 05:38 PM
09/23/11 05:38 PM
Hamburg, Pa.
72 RR DUDE Offline
72 RR DUDE  Offline
Hamburg, Pa.
I have tried to post pictures but it doesn't work. What is your e-mail address and I'll e-mail the pictures to you direct.
Re: Badly Stamped VIN Sequence #'s On Engines & Transmision [Re: 72 RR DUDE] #1038118
09/23/11 06:51 PM
09/23/11 06:51 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Re: Badly Stamped VIN Sequence #'s On Engines & Transmision [Re: ScottSmith_Harms] #1038119
10/02/11 10:49 PM
10/02/11 10:49 PM
Kingston, IL USA!
gts340swinger Offline
Kingston, IL USA!
I've seen several that are hard to read. I have a 72 340 that is missing the second digit in the sequence # entirely.
Mr. Norm's "Fanatic" (idiot)
71 Mr. Norm's Demon GSS
77 Mr. Norm's personal B250 GSS van
76 Mr. Norm's KZ900 Motor Sports Special
69 Mr. Norm's M code Dart GTS
69 D100
68 Barracuda
64 Valiant V200
07 Charger Daytona SST 6 speed test mule.
