Re: Badly Stamped VIN Sequence #'s On Engines & Transmision
[Re: Mr T2U]
#1038113
09/17/11 07:04 PM
09/17/11 07:04 PM
Posts: 2,316 South, FL
cudaized
South, FL
i have a 71 barracuda that there are NO VIN #'s on the core support OR the cowl.
Years ago, I looked at a 70 hemicuda. It had the same. No numbers stamped on the cowl nor radiator support. No Data Plate. Did not even have the holes drilled. After some research, it turned out to be a Body In White from the factory. Some how, some time, it recieved a V.I.N. plate. ![](/ubbthreads/images/graemlins/shruggy.gif)
[Re: ScottSmith_Harms]
#1038119
10/02/11 10:49 PM
10/02/11 10:49 PM
Posts: 6,480 Kingston, IL USA!
gts340swinger
Kingston, IL USA!
I've seen several that are hard to read. I have a 72 340 that is missing the second digit in the sequence # entirely.
Mr. Norm's "Fanatic" (idiot) 71 Mr. Norm's Demon GSS 77 Mr. Norm's personal B250 GSS van 76 Mr. Norm's KZ900 Motor Sports Special 69 Mr. Norm's M code Dart GTS 69 D100 68 Barracuda 64 Valiant V200 07 Charger Daytona SST 6 speed test mule.
