measuring flowmasters?? #1037996
07/22/11 03:17 PM
07/22/11 03:17 PM
poplar bluff mo.
toplescuda Offline OP
I Whine
I Whine
poplar bluff mo.
how do you measure the size of the muffler?inside or outside?
sounds stupid i know
bought pair of flowmasters (used) they were to be 3 in 3 out because our muffler shop cant bend anything bigger (for the 426 hemi challenger)
so they show up today and the out side of the tubes is like 2 3/4 so im like what the heck am i spossed to do with these???
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: measuring flowmasters?? [Re: toplescuda] #1037997
07/22/11 03:37 PM
07/22/11 03:37 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Since you say they "showed up" today, I take you didn't have the chance to inspect them before hand, but it sounds like you got duped.
Whether they were measured inside or outside diameter wouldn't matter in this case. The wall thickness isn't enough to make up a quarter of an inch. 2.75 is an available size of exhaust pipe, but is much more uncommon than 2.5 or 3. The easiest way to unload your odd ball stuff, call it something more common.
Re: measuring flowmasters?? [Re: toplescuda] #1037998
07/22/11 04:21 PM
07/22/11 04:21 PM
Birmingham, England
Mick70RR Offline
Mick70RR  Offline
Birmingham, England
It should be measured on the inside, the exhaust pipe slides into the muffler, sounds like you have 2.5" mufflers.
1970 Road Runner 505 cid MCH CNC ported Stealth heads MP 528 camshaft 4 speed GV overdrive 11.98 @ 117 on street treads
Re: measuring flowmasters?? [Re: Mick70RR] #1037999
07/22/11 05:41 PM
07/22/11 05:41 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
99% of the aftermarket highperf mufflers are measured by I.D
dont know how flowmasters are now they used to be pretty tight, if they are as bad in shape now as alot of other mufflers are a 2½ I.D" muffler can easily be misshaped enough to measure out at 2 3/4" O.D with the wallthicknes added
