Re: Reuse valley pan gasket?
[Re: mopeman]
#103803
08/12/08 04:34 PM
08/12/08 04:34 PM
DaytonaTurbo
Manitoba, Canada
I would take the pan right off and clean it on both sides. Sometimes when you pull an intake off, it can pull the pan away from the heads a little around the intake ports. Not enough to wreck the pan by any means, but sometimes enough that if there's any crud built up behind there, like if you used any adhesion/sealant products last time, it could prevent it from getting a good seal when you put your new intake on. So I'd pull the pan, clean it everywhere along with the mating surface on the heads, give it a fresh coat of permatex copper spray and bolt the new intake on.
[Re: DaytonaTurbo]
#103804
08/12/08 05:20 PM
08/12/08 05:20 PM
Posts: 21,079 Niles , Ohio
therocks
Niles , Ohio
RTV in the 4 corners and I run a light bead under where the hold down rails go.Thats all Ive done ever.Been reusing them since the 60s with no problems even with aluminum intakes and now aluminum heads.Rocky
Chrysler Firepower
