Band adjustment??? #1037895
07/22/11 10:16 AM
07/22/11 10:16 AM
S.E. Michigan
cl440 Offline OP
cl440  Offline OP
S.E. Michigan
I bought a 2001 caravan and am planning on a transmission fluid & filter change. I thought I would adjust the bands as long as I am in there. Does anyone know the specs for the band adjustment?
I believe it is the A413 (31TH) transmission because it is a 3 speed behind the 2.4L engine.
Re: Band adjustment??? [Re: cl440] #1037896
07/22/11 10:41 PM
07/22/11 10:41 PM
moparx Offline
moparx  Offline
kickdown band[yes, i know.....] snug to 72"lbs, back off 2 3/4 turns.
low/reverse band snug to 41"lbs,[yes, 41"lbs true torque], back off 3 1/2 turns.
this is taken from atsg service/rebuild manual.
Re: Band adjustment??? [Re: moparx] #1037897
07/23/11 10:04 AM
07/23/11 10:04 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
are those inch pounds?
Re: Band adjustment??? [Re: bonefish] #1037898
07/23/11 02:49 PM
07/23/11 02:49 PM
moparx Offline
moparx  Offline
yes.
