88 PLYMOUTH SUNDANCE / FUSE BLOWING #1037792
07/21/11 11:25 PM
07/21/11 11:25 PM
S.E.Ohio
Magnumguy Offline OP
S.E.Ohio
My bosses family member's car.
Blows dash light fuse when the h/l's are turned on. Was also blowing the taillight fuse as well, but that's settled down.
I'm figuring it's a wire rubbing something, but maybe there's a common issue?
thanks
"Multiple Magnum owner since 1978!!"
https://www.facebook.com/groups/146952895354657/
Re: 88 PLYMOUTH SUNDANCE / FUSE BLOWING [Re: Magnumguy] #1037793
07/23/11 12:52 PM
07/23/11 12:52 PM
S.E.Ohio
S.E.Ohio
Re: 88 PLYMOUTH SUNDANCE / FUSE BLOWING [Re: Magnumguy] #1037794
07/23/11 04:02 PM
07/23/11 04:02 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Recent install of aftermarket radio perhaps?
Re: 88 PLYMOUTH SUNDANCE / FUSE BLOWING [Re: buildanother] #1037795
07/23/11 05:27 PM
07/23/11 05:27 PM
S.E.Ohio
S.E.Ohio
Well, I believe so!!!
Re: 88 PLYMOUTH SUNDANCE / FUSE BLOWING [Re: Magnumguy] #1037796
07/23/11 09:08 PM
07/23/11 09:08 PM
chicagoland,usa
chicagoland,usa
Ah, so somebody gypsied the wiring.
Re: 88 PLYMOUTH SUNDANCE / FUSE BLOWING [Re: buildanother] #1037797
07/25/11 11:20 AM
07/25/11 11:20 AM
S.E.Ohio
S.E.Ohio
So, are they overloading the circuit or......
Re: 88 PLYMOUTH SUNDANCE / FUSE BLOWING [Re: Magnumguy] #1037798
07/25/11 11:43 AM
07/25/11 11:43 AM
chicagoland,usa
chicagoland,usa
I just think they hooked some wiring incorrectly, if an aftermarket radio was installed. The car originally had dimable face lighting etc, and if they used the wrong 12v source to power the new radio, it may not work well or blow some fuse or fuses.
