Re: HP for $$$
[Re: 1967dartgt]
#1037584
07/23/11 06:43 PM
07/23/11 06:43 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Oh, it also has a 11speaker stereo system with two amps and I would guess it weights about 3700 lbs race ready.
Brett Miller W9 cnc'd heads STR Chassis fabraction
Re: HP for $$$
[Re: fishy340]
#1037585
07/23/11 08:07 PM
07/23/11 08:07 PM
Posts: 2,275 Desert Tracker
HYPER8oSoNic
Desert Tracker
well thats what i mean,we can buy cheap for both,like cast cranks etc etc.. its all relative to make 500 isnt really that tuff anymore for either bb or sb.. im giving up its to hot.
The "econo" route isn't bad at all, but... there's a term called RELIABILITY when selecting parts for the assembly of a 550-600 hp motor (whether BB or SB). You must insure that the motor will make the 550-600hp, reliabily. A member previously posted about stress on the an engine at about 960 hp. That's true, and you would need NEARLY the BEST parts that money can buy for that power level and beyond. However, 550-600 hp does put SOME stress on the internals (reciprocating assembly) and at this level you NEED a bit more than you would at the 500 hp level. MORE than a "warmed over" Magnum motor (400-450 hp, BB or SB) would need. Think about stress on crank/rod/piston assembilies, and at every 1000rpms (over 5500 rpms) the force keeps increasing itself, squared (check on this). So much more factors come into play when increasing power. Big Blocks are more TORQUE productive than Small Blocks and build it STRONG, FROM above idle going thru the midrange rpms. The bigger block design contributes to this, but they are victims to excessive bobweight. Rev potential (NOT hp) is less in the Big Block. The Small Blocks' claim to fame IS the fact of lesser bobweight and with that comes BETTER rev potential (more hp/torque upstairs, equipment depending) with increased "breathing" capability. But their downside is LESS torque (than the Big Block) in the lower ranges. That's why Small Blocks NEED more multiplication (gears) than the Big Block.
"Stupidity is Ignorance on Steroids" "Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
Re: HP for $$$
[Re: d-150]
#1037587
07/23/11 09:06 PM
07/23/11 09:06 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
stock 440 steel crank ,stock ly rods ,liter pistons could handle 600hp no problem not even working the block.i think if i built a small block that level it would be aftermarket stroker crank possibly steel crank scat rods. that is the price difference.but my 440 build i used scat rods i got off ebay brand new 180.00 dollars.my machinist really had to cut on the crank
this guy gets it. And you don't have to spin it to 7k to make the power.
Re: HP for $$$
[Re: pittsburghracer]
#1037590
07/23/11 11:21 PM
07/23/11 11:21 PM
1967dartgt
Hilltown Pa
As stated on other post the car is a protouring car running 17in tires 6 piston bear brakes 13 front 12 in the back full leather interior was just a feature car in a big mag runs on pump gas should go 9.50s at the track in street trim and is a dog? What does that make your sons car a super slug? R10.50s in a car set up to go race. Sorry he's not here to defend himself as her is at the track racing his car and not here . He added 200-300# t hmore to his car this week as he was told to slow it down more till he gets the roll bar in after running a 11.40 on the brakes last week in the 5th round. I would love to see how fast it would go in the Fall with the 300-400# he's added so far out of it and the four barrel hooked back up. [/quote So I see you cant answer questions. How do you figure a pumpgas small block on 17 in dragradials protouring car in street trim through exaust to the rear bumper, full leather interior front and rear seats that should run 9.50s is a slug. I think there are alot of people on here with race cars that are that fast. I am asking you not your son, asked for your opinion on your sons car not his.
Re: HP for $$$
[Re: d-150]
#1037592
07/23/11 11:37 PM
07/23/11 11:37 PM
1967dartgt
Hilltown Pa
Well I guess you also have a street car this fast? Mr d150.
Re: HP for $$$
[Re: d-150]
#1037594
07/23/11 11:51 PM
07/23/11 11:51 PM
1967dartgt
Hilltown Pa
In the other thread you want to build a 360 magnum roller for a duster? And a bigblock dakota and a 273 nitro car woo you are busy!!
Re: HP for $$$
[Re: d-150]
#1037597
07/24/11 01:28 AM
07/24/11 01:28 AM
HYPER8oSoNic
Desert Tracker
I think at that high level of hp (550-600) and a nearly EQUAL amount of torque, I would be thinking about not reusing the stock reciprocating assembly and get brand new crank/rods from the factory, MP or Scat. Whether Big Block OR Small Block, after 35-45 years from the assembly line, the original parts do not have 100% shelf life (tired) and you apply 550-600 hp to them, IMO something's gotta give. It's called putting money in the RIGHT PLACES.
Re: HP for $$$
[Re: whiskeyrunner]
#1037601
07/25/11 02:41 PM
07/25/11 02:41 PM
Posts: 2,578 sweden
1Fast340
sweden
yea good idea bro...lets melt all the small blocks down!
im going to do my best trying to melt a smallblock down from inside..
Re: HP for $$$
[Re: whiskeyrunner]
#1037602
07/25/11 08:16 PM
07/25/11 08:16 PM
Posts: 3,112 LONG ISLAND
fishy340
LONG ISLAND
u dont need to melt anything just hit A stock 440 w 600hp and it'll crack all on its own...lol
Re: HP for $$$
[Re: Streetwize]
#1037603
07/25/11 09:05 PM
07/25/11 09:05 PM
HYPER8oSoNic
Desert Tracker
for 550 hp reliably and most economically...I'd say the 511 B or RB motor with bowl worked E heads and a 255 @.050 .600 lift cam, A St Dommy intake and an 850 carb. I said Economical in terms of least $$$ for the Bang...nothing done right and built to last is truly "cheap".
Buy the E-heads off somebody that just upgraded to Max wedge heads (like many eventually do)
Nothing exotic about the shortblock kit, just top notch machine work and careful assembly.
Easy 550hp, and yes, you can get 550 out of a stock stroke 440 or 451 B....but your streetability will be more reliant on a looser stall and deeper gears. If it's a bracket only car you can surely get there and the streetability isn't an issue.
Case in point...I just did a 414 small block, horse trading parts and a a used solid roller cam I'm pretty safe telling you it makes an easy 550, I can also tell you it cost about $1200-1500 more than if I did the 'economical' 511 I just described above....The extra $$$ is typically in the needed head porting plus the typically higher grade valvetrain you need to reliably spin the motor high enough to use it. But a B motor don't fit too well in my car. Don't get me wrong I love it but at 500-600 Reliable HP a B/RB is the way to go...the reason is mainly the heads, Small block heads can make that kind of power...but not really out of the box. conversely, I'm pretty certain just about anybody can make 550hp easy (and with broader overall torque and less RPM) with a set of BB E-heads on a 470-up motor pretty easy.....with nothing more than and ultra streetable 235 ish at .050 Hydraulic Flat tap.
Horsepower targets are typically all about head flow requirements...with less regard to cubes (when you make it up with RPM), torque curves and how you wish to apply it to the ground is really a completely different (and application specific) arguement.
This is why he is "WIZE"!! Excellent points!!
