Housing End Bolts #1037480
07/21/11 05:37 PM
07/21/11 05:37 PM
Iowa
E
eaglesguy1981j Offline OP
E
Iowa
What do you guys use for the housing end bolts that hold the backing plates and axles to the flange? I know Tee Bolts are correct but I havent located a source for them?
Some say to use regular bolts but grind them down. Which should I use a grade 5 or 8 if you I go that route.
Re: Housing End Bolts [Re: eaglesguy1981j] #1037481
07/21/11 05:42 PM
07/21/11 05:42 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Mancini has the correct hardware package.
http://chucker54.stores.yahoo.net/hoendstwanut.html
Re: Housing End Bolts [Re: John_Kunkel] #1037482
07/21/11 05:53 PM
07/21/11 05:53 PM
Iowa
E
E
Iowa
See now I was told they were Tee Bolts. But studs make sense too.
Re: Housing End Bolts [Re: eaglesguy1981j] #1037483
07/21/11 06:50 PM
07/21/11 06:50 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
get them out of the Dorman box at your favorite parts house...
I am truckless..
