zinc anode #1037146
07/21/11 08:23 AM
07/21/11 08:23 AM
Ontario.Canada
can.al Offline OP
can.al  Offline OP
Ontario.Canada
who has had an electrolisis problem with their aluminum components,
or is this a saltwater marine problem.
..thinking about getting an alum rad.
Re: zinc anode [Re: can.al] #1037147
07/21/11 12:18 PM
07/21/11 12:18 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I have one hanging inside the radiators on 2 cars, both of which have Aluminum heads & intake, one has alum rad. Both have anti-freeze & water-wetter in them.
The anode in the car with OEM rad is sacrificing itself much quicker than the alum rad car; possibly because there's less aluminum to attack, but neither car has had any noticeable problems.
Re: zinc anode [Re: topside] #1037148
07/21/11 01:56 PM
07/21/11 01:56 PM
Arizona
az426john Offline
az426john  Offline
Arizona
Could you tell me where you got got the Zinc Anodes and how did you hang them?
Re: zinc anode [Re: az426john] #1037149
07/21/11 02:45 PM
07/21/11 02:45 PM
Ontario.Canada
can.al Offline OP
can.al  Offline OP
Ontario.Canada
e bay ... zinc anode.
one style installs in your rad drain valve opening.
Re: zinc anode [Re: az426john] #1037150
07/21/11 03:39 PM
07/21/11 03:39 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
you can get them at anyplace that sells marine/boat hardware , standard in that application , why deal with mail order when you can go down the street and get them ?
