WILL 3:54 GEARS WORK FOR A 3:55 DIFF? #1036793
07/20/11 09:26 PM
07/20/11 09:26 PM
ALBERTA CANADA
CUDA8U Offline OP
CUDA8U  Offline OP
ALBERTA CANADA
Re: WILL 3:54 GEARS WORK FOR A 3:55 DIFF? [Re: CUDA8U] #1036794
07/20/11 09:40 PM
07/20/11 09:40 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Need more info here. the 3.54 sounds like a Dana 60 ratio. The 3.55 was common in the 8 3/4 axles. If that is the question, then... no. Those two axles do not share differential parts.
Re: WILL 3:54 GEARS WORK FOR A 3:55 DIFF? [Re: CUDA8U] #1036795
07/20/11 09:43 PM
07/20/11 09:43 PM
Arizona
az426john Offline
az426john  Offline
Arizona
Which rear end are you talking about?
7-1/4, 8-1/4, 8-3/4, 9-1/4?
Typically, 3:54 gears are for 9-1/4 Dana and 3:55 are for others.
Re: WILL 3:54 GEARS WORK FOR A 3:55 DIFF? [Re: az426john] #1036796
07/21/11 01:33 AM
07/21/11 01:33 AM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
I'm pretty sure that the 9 1/4 is a Chrysler built axle. The 9 3/4 DANA 60 is a separate unit.
