Mopar Performance Max Wedge heads for a 470 build #1036531
07/20/11 01:51 PM
07/20/11 01:51 PM
Manitoba, Canada
O
Overdrive440 Offline OP
O
Manitoba, Canada
Has anybody here built an engine with the Mopar Performance P5007494 Max Wedge heads?
I am interested in using these heads to build an engine for my truck to use in some local sled pulls. The rules state: "Engine size is 480 cubic inches with +/- 2% for pump accuracy. Engine block and heads must be cast iron. Must have OEM casting numbers." To meet this, I am considering building a 470 stroker using my truck's 400 block and using these max wedge heads and an Indy 400-2 4150 single plane intake manifold, which, to me, meets the rules.
This being said, I have not found much information on building these heads, or who can best set these up. I am looking for tips and advice on using these heads, and what work they need to set them up, as they come bare. I'm not wanting to spend a fortune, but want a solid foundation to work with.
Re: Mopar Performance Max Wedge heads for a 470 build [Re: Overdrive440] #1036532
07/20/11 02:32 PM
07/20/11 02:32 PM
Try contacting Bob Goerge Racing(a member on here ) and see if he has any expereinces with them
Re: Mopar Performance Max Wedge heads for a 470 build [Re: Overdrive440] #1036533
07/20/11 04:00 PM
07/20/11 04:00 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Here's a thread about them, from awhile back:
https://board.moparts.org/ubbthreads/show...e=0#Post6397899
Rich H.
Esse Quam Videri
Re: Mopar Performance Max Wedge heads for a 470 build [Re: Overdrive440] #1036534
07/20/11 10:54 PM
07/20/11 10:54 PM
AndyF Online content
AndyF  Online Content
Dwayne Porter can set the heads up for you. Intake choices are going to stink. The Indy will fit but then the valley will be a mess to seal up.
Re: Mopar Performance Max Wedge heads for a 470 build [Re: AndyF] #1036535
07/23/11 08:01 PM
07/23/11 08:01 PM
Manitoba, Canada
O
O
Manitoba, Canada
yeah, I read up on intake choices in one of your articles I believe. One option, I can fab up something that will work, or use my 440 core for building up.
I'll contact Dwayne Porter to see what he recommends.
Re: Mopar Performance Max Wedge heads for a 470 build [Re: Overdrive440] #1036536
07/23/11 09:15 PM
07/23/11 09:15 PM
If you have a 440 block to use then you get a lot more intake choices. The cleanest setup with an RB block is to use the Mopar 337 intake. The 337 intake seals up the valley for a nice simple assembly. It is a low rise design but it makes plenty of power.
Re: Mopar Performance Max Wedge heads for a 470 build [Re: AndyF] #1036537
07/24/11 01:25 PM
07/24/11 01:25 PM
Manitoba, Canada
O
O
Manitoba, Canada
Good to know for the intake. Thanks for the tip. I'll look into that.
