Mopar Performance Max Wedge heads for a 470 build #1036531
07/20/11 01:51 PM
07/20/11 01:51 PM
Manitoba, Canada
O
Overdrive440 Offline OP
O
Manitoba, Canada
Has anybody here built an engine with the Mopar Performance P5007494 Max Wedge heads?
I am interested in using these heads to build an engine for my truck to use in some local sled pulls. The rules state: "Engine size is 480 cubic inches with +/- 2% for pump accuracy. Engine block and heads must be cast iron. Must have OEM casting numbers." To meet this, I am considering building a 470 stroker using my truck's 400 block and using these max wedge heads and an Indy 400-2 4150 single plane intake manifold, which, to me, meets the rules.
This being said, I have not found much information on building these heads, or who can best set these up. I am looking for tips and advice on using these heads, and what work they need to set them up, as they come bare. I'm not wanting to spend a fortune, but want a solid foundation to work with.
Re: Mopar Performance Max Wedge heads for a 470 build [Re: Overdrive440] #1036532
07/20/11 02:32 PM
07/20/11 02:32 PM
Try contacting Bob Goerge Racing(a member on here ) and see if he has any expereinces with them
Re: Mopar Performance Max Wedge heads for a 470 build [Re: Overdrive440] #1036533
07/20/11 04:00 PM
07/20/11 04:00 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Here's a thread about them, from awhile back:
https://board.moparts.org/ubbthreads/show...e=0#Post6397899
Rich H.
Esse Quam Videri
Re: Mopar Performance Max Wedge heads for a 470 build [Re: Overdrive440] #1036534
07/20/11 10:54 PM
07/20/11 10:54 PM
AndyF Offline
AndyF  Offline
Dwayne Porter can set the heads up for you. Intake choices are going to stink. The Indy will fit but then the valley will be a mess to seal up.
Re: Mopar Performance Max Wedge heads for a 470 build [Re: AndyF] #1036535
07/23/11 08:01 PM
07/23/11 08:01 PM
Manitoba, Canada
O
O
Manitoba, Canada
yeah, I read up on intake choices in one of your articles I believe. One option, I can fab up something that will work, or use my 440 core for building up.
I'll contact Dwayne Porter to see what he recommends.
Re: Mopar Performance Max Wedge heads for a 470 build [Re: Overdrive440] #1036536
07/23/11 09:15 PM
07/23/11 09:15 PM
AndyF Offline
AndyF  Offline
If you have a 440 block to use then you get a lot more intake choices. The cleanest setup with an RB block is to use the Mopar 337 intake. The 337 intake seals up the valley for a nice simple assembly. It is a low rise design but it makes plenty of power.
Re: Mopar Performance Max Wedge heads for a 470 build [Re: AndyF] #1036537
07/24/11 01:25 PM
07/24/11 01:25 PM
Manitoba, Canada
O
O
Manitoba, Canada
Good to know for the intake. Thanks for the tip. I'll look into that.
