hemi block vin numbers #1036173
07/19/11 09:14 PM
07/19/11 09:14 PM
Indiana
maxie Offline OP
maxie  Offline OP
Indiana
Can you tell what car this came out of by these numbers? It is in a clone car and the guy has made comments about "if" the correct car was out there he would trade it.
Re: hemi block vin numbers [Re: maxie] #1036174
07/19/11 09:19 PM
07/19/11 09:19 PM
phx, az.
J code Chargers Offline
phx, az.
That really isn't a VIN number. Those are assembly numbers based on the 10,000 day calendar. The VIN number should be stamped on the top of the motor near the oil sending unit on the rail where the bellhousing bolts to the back of the motor.
Re: hemi block vin numbers [Re: J code Chargers] #1036175
07/19/11 09:24 PM
07/19/11 09:24 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Correct! However, the late April 1968 Assembly date will tell you that it's likely from a May 1968 Hemi car but not much else.
Re: hemi block vin numbers [Re: maxie] #1036176
07/19/11 09:27 PM
07/19/11 09:27 PM
phx, az.
phx, az.
Actually, my 68 Hemi Charger was built in May 68. If the vin on the motor is 375868 please let me know and I'll buy this motor and make you a deal on the motor that is currently in my Charger.
Hey, it's worth a shot!!
Re: hemi block vin numbers [Re: J code Chargers] #1036177
07/19/11 10:51 PM
07/19/11 10:51 PM
INDIANA
HEMI ROY Offline
HEMI ROY  Offline
INDIANA
Thanks Guys it's my car friend posted for me !!
Re: hemi block vin numbers [Re: J code Chargers] #1036178
07/20/11 07:44 PM
07/20/11 07:44 PM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
Ditto on the May 68 Hemi car - Plymouth. Although a May built motor could be early 69 as well. Anyway if the numbers come back 287580, I'm in!!
Re: hemi block vin numbers [Re: 68jim] #1036179
07/22/11 04:16 PM
07/22/11 04:16 PM
Virginia
HemiStan Offline
HemiStan  Offline
Virginia
I'm looking for mine as well. Last three of the VIN are 318.
Stan
Re: hemi block vin numbers [Re: HEMI ROY] #1036180
07/22/11 10:27 PM
07/22/11 10:27 PM
currently on moparts.
Race&Resto Offline
Race&Resto  Offline
Thanks Guys it's my car, friend posted for me !!
Take some pictures of the # number located on the back of the motor on the bell housing flange.
Re: hemi block vin numbers [Re: Race&Resto] #1036181
07/22/11 11:19 PM
07/22/11 11:19 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
They're over here in GENERAL
