How much"play" in stamped rockers on shaft #1035891
07/19/11 02:01 PM
07/19/11 02:01 PM
Hr up from KCK
451 D*O*D*G*E Offline OP
Hr up from KCK
I had one real bad stamped rocker so i replaced them with the Mopar HYD units..pulled a few out and slid them on shaft they have plenty of play as well is this normal????
Shafts michro'ed ok.
1970 Challenger R/T clone 2010 Dodge Journey R/T black,awd,
Re: How much"play" in stamped rockers on shaft [Re: 451 D*O*D*G*E] #1035892
07/19/11 02:25 PM
07/19/11 02:25 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
yes it is normal. The pressure is on the bottom of the rocker pushing it up against the shaft. Gap on the top makes no difference.
Re: How much"play" in stamped rockers on shaft [Re: MoparforLife] #1035893
07/19/11 02:46 PM
07/19/11 02:46 PM
Hr up from KCK
Hr up from KCK
Thanks sir.I thought it had to be something like that cause new checks out and the shafts were good.Thanks!
