Page 4 of 15 1 2 3 4 5 6 14 15
Re: big block VS small block [Re: RemCharger] #1035475
07/19/11 10:00 PM
07/19/11 10:00 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
If you take the best factory 440 (sixpack) you should be able to get 500 with a cam and intake , rockers, headers.Throw in some cylinder head work too.. for laughs.
I can't see that happening with a 360. And if I'm right, there goes the budget deal. (which wasn't really in the original question)
right Rem... a SB will not make 500 easier or cheaper than a 440. 360 vs 440..... 440 WIN
Re: big block VS small block [Re: Mr.Yuck] #1035476
07/19/11 10:05 PM
07/19/11 10:05 PM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
That's not what the OP is asking. Even though I agree.
Re: big block VS small block [Re: viperblue72] #1035477
07/19/11 10:11 PM
07/19/11 10:11 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
lol U R right. I'm not real smart, but wouldn't the engine that got to 500hp and max torque get to the stripe 1st?
Re: big block VS small block [Re: Mr.Yuck] #1035478
07/19/11 10:36 PM
07/19/11 10:36 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
Only with identical convertors.
Re: big block VS small block [Re: Mr.Yuck] #1035479
07/19/11 10:41 PM
07/19/11 10:41 PM
South Central Pa
webemopes Offline
webemopes  Offline
South Central Pa
the original post asked if all things being equal, which one would be quicker.same 500 horsepower,same 3000 lbs,stock stroke.torque is what moves weight,not horsepower.the extra stroke of the 440 would make it quicker to move a 1/4 mi.i am a fan of both,but without getting in to better heads bigger cams and the such,a bigblock gives more bang for the buck.if you don`t mind a little more maintenance,then run a higer reving small block.if you want to build it and close the hood and lug the thing then do a bigblock.
Re: big block VS small block [Re: w7smallblock] #1035480
07/19/11 10:55 PM
07/19/11 10:55 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Lets say you build a 440 and a 360 both stock stroke to make the same horse power (500hp). Do you agree the 440 will make more torque given the larger stroke? Do you think with properly matched gear and converter for the engines in say a 3000lb car will run the same ET? If they do run the same ET does this mean the smallblock would recover in between gear changes quicker to make up for being down on torque. I am trying to end an argument, so your thoughts please.
The 440 will have the larger more average power band over the 360. Hands down in the above senario it would be the winner.
Further, any mopar SB stroked bigger then 3.379 is a BB IMO
Re: big block VS small block [Re: w7smallblock] #1035481
07/19/11 10:58 PM
07/19/11 10:58 PM
Arizona
Chris'sBarracuda Offline
Arizona
Lets say you build a 440 and a 360 both stock stroke to make the same horse power (500hp). A.- Do you agree the 440 will make more torque given the larger stroke? B.- Do you think with properly matched gear and converter for the engines in say a 3000lb car will run the same ET? C.- If they do run the same ET does this mean the smallblock would recover in between gear changes quicker to make up for being down on torque. I am trying to end an argument, so your thoughts please.
http://www.wallaceracing.com/Calculators.htm
Wallace Racing - ET/MPH/HP Calculator Weight is as the car sits on the line: driver and gas in it.
Calculate ET and MPH from HP and Weight
Weight HP
Your ET / MPH computed from your vehicle weight of 3000 pounds and HP of 500 is 10.58 seconds and MPH of 126.58 MPH.
It doesn't ask if it is a 360 or 440.. Guess What.. It Doesn't Care..
Chris..
Re: big block VS small block [Re: webemopes] #1035482
07/19/11 11:04 PM
07/19/11 11:04 PM
NC
barracuda man Offline
NC
what would a 340 30/over factory 3.31 stroke be 344cubes?
3100 barracuda with driver.been 6.84 et @98mph 1/8 mile/ with otb eheads/rpm air gap/750 carb/258*/268*@50 roller cam/kb pistons/10.0 compression/power glide trans.Bring the big block on with = parts and watch what happens.
Re: big block VS small block [Re: earthmover] #1035483
07/19/11 11:21 PM
07/19/11 11:21 PM
V
viperblue72 Offline
viperblue72  Offline
V
look out for the im gone lol mike
I'm gonna join earthmover here.
Re: big block VS small block [Re: emarine01] #1035484
07/19/11 11:34 PM
07/19/11 11:34 PM
Toronto
mshred Offline
mshred  Offline
Toronto
I think that fat guys need big blocks and thin guys need small blocks, and when you put a fat guy in a small block you need a fatter wallet.... and that's all there is too it
this
who could have ever thought that BB vs. SB discussion could turn out worse than kids fighting for candy on the playground?
Re: big block VS small block [Re: barracuda man] #1035485
07/19/11 11:56 PM
07/19/11 11:56 PM
MD.
V
vttm Offline
vttm  Offline
V
MD.
I just pulled some time slips from june of 05 this was a very mild 440 build using the stock crank, stock rods,.030 over TRW pistons with 10.3 to 1 comp. with out of the box eddy heads and a mopar .590 solid flat tappet cam in a 69 valiant street car 3115 race weight set up for 1/4 went 6.739 @ 102.66 in 1/8. So there's a big block = parts so what would happen??
Re: big block VS small block [Re: vttm] #1035486
07/20/11 12:06 AM
07/20/11 12:06 AM
Peru
cbarracuda Offline
cbarracuda  Offline
Peru
Luckily for the big block guys we are talking about straight line acleration here because if we talk road racing there is no way to make a turn with a boat anchor in the front
Re: big block VS small block [Re: vttm] #1035487
07/20/11 12:08 AM
07/20/11 12:08 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Thats a 727 VS a glide
Re: big block VS small block [Re: vttm] #1035488
07/20/11 12:20 AM
07/20/11 12:20 AM
NC
NC
The glide slow the car down a tenth.plus a 750 carb setup lean 78/78 jets.Not to mention my .001 reaction time to your .100 bulb.I'll get thier first.
Re: big block VS small block [Re: MR_P_BODY] #1035489
07/20/11 12:24 AM
07/20/11 12:24 AM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
68 dart stock stroke .030 440 pg eddy heads roller cam 6.32 @ 109 mph , april 2010 I have time slips, went to a 520 this yr
Re: big block VS small block [Re: Mopar-Al] #1035490
07/20/11 12:30 AM
07/20/11 12:30 AM
NC
NC
Re: big block VS small block [Re: barracuda man] #1035491
07/20/11 12:32 AM
07/20/11 12:32 AM
MD.
V
vttm Offline
vttm  Offline
V
MD.
Probably so. Thats a very stout combo you have there.
Re: big block VS small block [Re: vttm] #1035492
07/20/11 12:37 AM
07/20/11 12:37 AM
NC
NC
It's all Good as long as its MOPAR.
Re: big block VS small block [Re: cbarracuda] #1035493
07/20/11 12:54 AM
07/20/11 12:54 AM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
Makes sense. The big block makes it a muscle car. Muscle cars weren't meant to go road racing.
Re: big block VS small block [Re: BB70DUSTER] #1035494
07/20/11 02:04 AM
07/20/11 02:04 AM
Mira Loma, CA
69B3GT Offline
69B3GT  Offline
Mira Loma, CA
Ive seen 7600 out of a stock stroke 360 with mildy ported iron heads and a .484MP cam. Bash away.
I dont think my 440 will go that high (okay okay, I know it wont)
haha, Ive had stock big blocks higher Chris! BUT, your not making any power revving it that high...
I hear that Mike, it was accidental that the 360 went that high, now it just sees 7k tops.
