Re: big block VS small block
[Re: RemCharger]
#1035475
07/19/11 10:00 PM
07/19/11 10:00 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
If you take the best factory 440 (sixpack) you should be able to get 500 with a cam and intake , rockers, headers.Throw in some cylinder head work too.. for laughs.
I can't see that happening with a 360. And if I'm right, there goes the budget deal. (which wasn't really in the original question)
right Rem... a SB will not make 500 easier or cheaper than a 440. 360 vs 440..... 440 WIN
[Re: Mr.Yuck]
#1035476
07/19/11 10:05 PM
07/19/11 10:05 PM
Posts: 2,141 junction city oregon
viperblue72
That's not what the OP is asking. Even though I agree.
[Re: viperblue72]
#1035477
07/19/11 10:11 PM
07/19/11 10:11 PM
Mr.Yuck
Brookeville, Md
lol U R right. I'm not real smart, but wouldn't the engine that got to 500hp and max torque get to the stripe 1st?
[Re: Mr.Yuck]
#1035478
07/19/11 10:36 PM
07/19/11 10:36 PM
Posts: 2,825 Sk. Canada
RemCharger
Sk. Canada
Only with identical convertors.
[Re: w7smallblock]
#1035480
07/19/11 10:55 PM
07/19/11 10:55 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
Lets say you build a 440 and a 360 both stock stroke to make the same horse power (500hp). Do you agree the 440 will make more torque given the larger stroke? Do you think with properly matched gear and converter for the engines in say a 3000lb car will run the same ET? If they do run the same ET does this mean the smallblock would recover in between gear changes quicker to make up for being down on torque. I am trying to end an argument, so your thoughts please.
The 440 will have the larger more average power band over the 360. Hands down in the above senario it would be the winner.
Further, any mopar SB stroked bigger then 3.379 is a BB IMO
[Re: w7smallblock]
#1035481
07/19/11 10:58 PM
07/19/11 10:58 PM
Posts: 3,667 Arizona
Chris'sBarracuda
Arizona
Lets say you build a 440 and a 360 both stock stroke to make the same horse power (500hp). A.- Do you agree the 440 will make more torque given the larger stroke? B.- Do you think with properly matched gear and converter for the engines in say a 3000lb car will run the same ET? C.- If they do run the same ET does this mean the smallblock would recover in between gear changes quicker to make up for being down on torque. I am trying to end an argument, so your thoughts please.
http://www.wallaceracing.com/Calculators.htm
Wallace Racing - ET/MPH/HP Calculator Weight is as the car sits on the line: driver and gas in it. Calculate ET and MPH from HP and Weight Weight HP Your ET / MPH computed from your vehicle weight of 3000 pounds and HP of 500 is 10.58 seconds and MPH of 126.58 MPH.
It doesn't ask if it is a 360 or 440.. Guess What.. It Doesn't Care..
Chris..
[Re: webemopes]
#1035482
07/19/11 11:04 PM
07/19/11 11:04 PM
Posts: 526 NC
barracuda man
NC
what would a 340 30/over factory 3.31 stroke be 344cubes? 3100 barracuda with driver.been 6.84 et @98mph 1/8 mile/ with otb eheads/rpm air gap/750 carb/258*/268*@50 roller cam/kb pistons/10.0 compression/power glide trans.Bring the big block on with = parts and watch what happens.
[Re: emarine01]
#1035484
07/19/11 11:34 PM
07/19/11 11:34 PM
Posts: 3,415 Toronto
mshred
Toronto
I think that fat guys need big blocks and thin guys need small blocks, and when you put a fat guy in a small block you need a fatter wallet.... and that's all there is too it
this
who could have ever thought that BB vs. SB discussion could turn out worse than kids fighting for candy on the playground?
[Re: barracuda man]
#1035485
07/19/11 11:56 PM
07/19/11 11:56 PM
Posts: 188 MD.
vttm
MD.
I just pulled some time slips from june of 05 this was a very mild 440 build using the stock crank, stock rods,.030 over TRW pistons with 10.3 to 1 comp. with out of the box eddy heads and a mopar .590 solid flat tappet cam in a 69 valiant street car 3115 race weight set up for 1/4 went 6.739 @ 102.66 in 1/8. So there's a big block = parts so what would happen??
[Re: vttm]
#1035487
07/20/11 12:08 AM
07/20/11 12:08 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Thats a 727 VS a glide
[Re: vttm]
#1035488
07/20/11 12:20 AM
07/20/11 12:20 AM
Posts: 526 NC
barracuda man
NC
The glide slow the car down a tenth.plus a 750 carb setup lean 78/78 jets.Not to mention my .001 reaction time to your .100 bulb.I'll get thier first.
[Re: MR_P_BODY]
#1035489
07/20/11 12:24 AM
07/20/11 12:24 AM
Posts: 6,780 Alabama
Mopar-Al
Alabama
68 dart stock stroke .030 440 pg eddy heads roller cam 6.32 @ 109 mph , april 2010 I have time slips, went to a 520 this yr
[Re: Mopar-Al]
#1035490
07/20/11 12:30 AM
07/20/11 12:30 AM
Posts: 526 NC
barracuda man
NC
[Re: barracuda man]
#1035491
07/20/11 12:32 AM
07/20/11 12:32 AM
Posts: 188 MD.
vttm
MD.
Probably so. Thats a very stout combo you have there.
[Re: vttm]
#1035492
07/20/11 12:37 AM
07/20/11 12:37 AM
Posts: 526 NC
barracuda man
NC
It's all Good as long as its MOPAR.
[Re: cbarracuda]
#1035493
07/20/11 12:54 AM
07/20/11 12:54 AM
RemCharger
Sk. Canada
Luckily for the big block guys we are talking about straight line acleration here because if we talk road racing there is no way to make a turn with a boat anchor in the front
Makes sense. The big block makes it a muscle car. Muscle cars weren't meant to go road racing.
[Re: BB70DUSTER]
#1035494
07/20/11 02:04 AM
07/20/11 02:04 AM
Posts: 1,894 Mira Loma, CA
69B3GT
Mira Loma, CA
Ive seen 7600 out of a stock stroke 360 with mildy ported iron heads and a .484MP cam. Bash away.
I dont think my 440 will go that high (okay okay, I know it wont)
haha, Ive had stock big blocks higher Chris! BUT, your not making any power revving it that high...
I hear that Mike, it was accidental that the 360 went that high, now it just sees 7k tops.
