Temp. Sending unit fitting #103541
08/11/08 11:56 PM
08/11/08 11:56 PM
Missouri
Confusedcuda Offline OP
Missouri
Does anyone know where to get the rubber little elbow fitting that goes ontop of the temp. sending unit on the manifold. I am going to stick with using the stock gauge which has worked well, but have checked yearone Laysons,etc. Any ideas? There is a little bit of the wire on the end and I may be able to cut the boot a little and use the one I got. Thanks It is for my stock 67 small block.
Re: Temp. Sending unit fitting [Re: Confusedcuda] #103542
08/12/08 01:21 AM
08/12/08 01:21 AM
Missouri
Missouri
Any Ideas?
Re: Temp. Sending unit fitting [Re: Confusedcuda] #103543
08/12/08 07:38 AM
08/12/08 07:38 AM
md
mopars4ever Offline
mopars4ever  Offline
md
I`m sure someone here may have good used one. If not, maybe they will sell you one. http://evanswiring.tripod.com/
