Tips on how to repair screw holes in console
#1035394
07/19/11 12:47 AM
07/19/11 12:47 AM
Posts: 1,043 Motown, Mi
PAULS_340
Motown, Mi
When remounting the hindged cover on my Abody console, some of the screw holes in the body were stripped. The body is some kind of fibre plastic composite??? What will fix the holes so I can re-screw mount the hindge? Thanks
Still looking for LM29H1B415501, '71 Demon 340
Re: Tips on how to repair screw holes in console
[Re: PAULS_340]
#1035395
07/19/11 01:25 AM
07/19/11 01:25 AM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
how's about a slightly larger screw. I don't see much else. unless you fill the holes and then re drill 'em. Fiberglass maybe.
I have mechanical Aptitude. I can screw up anything.
[Re: DirectSubjection]
#1035401
07/19/11 06:20 AM
07/19/11 06:20 AM
Posts: 27,728 places
79powerwagon
places
Not familar with that piece, but could you slip a speed clip in a spot or two for fastneing?
This was my idea too. Speed-nuts are your friend! The epoxy ideas are not great ideas primarily because you cannot identify the console material and have no way of know how the adhesives will work or react with it.
[Re: Stanton]
#1035407
07/19/11 07:42 PM
07/19/11 07:42 PM
Posts: 1,181 Lost in the ozone again
stubbs300
Vacation
Vacation
Baking soda and crazy glue create a chemical reaction and will smoke slightly during the process.
In my opinion this stuff beats any other product - epoxy or otherwise - because the thin viscosity of the crazy glue allows it to seep into every minute crack and crevice, unlike thick epoxies or JB Weld.
Yes, this will work as I have done this many a time when I had a franchaise. HOWEVER, be very careful and do this in a well ventalated area as the chemical reaction and the smoke is very toxic and can kill if not careful. Be forwarned.
