1966 & 1967 center console tachs........... #1034900
07/18/11 11:51 AM
07/18/11 11:51 AM
Ohio
440727 Offline OP
440727  Offline OP
Ohio
Is there any difference between a 1966 and a 1967 center console tach for B bodies ?
Thanks guys !
Re: 1966 & 1967 center console tachs........... [Re: 440727] #1034901
07/18/11 01:26 PM
07/18/11 01:26 PM
BC Canada
O
ogopogo Offline
ogopogo  Offline
O
BC Canada
they look the same but the 66 uses a remote sending unit,the 67 tach does not,here is a picture of a 66 with the wiring and sending unit.
Re: 1966 & 1967 center console tachs........... [Re: ogopogo] #1034902
07/18/11 07:11 PM
07/18/11 07:11 PM
Ohio
440727 Offline OP
440727  Offline OP
Ohio
Thanks !
But everything else is the same ? With a remote I'm guessing the wiring is different but can you switch it over to a non remote ? Does it really matter which way ? Which way is easier ?
Thanks guys !
Re: 1966 & 1967 center console tachs........... [Re: 440727] #1034903
07/19/11 09:54 AM
07/19/11 09:54 AM
Ohio
440727 Offline OP
440727  Offline OP
Ohio
Bump
Re: 1966 & 1967 center console tachs........... [Re: 440727] #1034904
07/19/11 12:14 PM
07/19/11 12:14 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
What sending unit? does it not just use one wire to the coil like all other tachs? then one wire each for light and ground.
Not sure what's in that picture. It looks like two tachs to me. One upside down. Or a vacuum gauge, what is that black thing that looks like a vacuum hose? I am sure I am wrong, but that is what it looks like to me.
Could you maybe use a new after market tach and put it in the stock housing? They should just use one wire to the coil. No?
I have mechanical Aptitude.
I can screw up anything.
Re: 1966 & 1967 center console tachs........... [Re: ogopogo] #1034905
07/19/11 01:45 PM
07/19/11 01:45 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
A lot of the early tachs used a remote sender.I have an old S W that takes a sender.No they wont work without a sender.The non sender tach would probally be easier as you dont need to find the sender.That looks like factory wrap around a wire to protect it.Rocky
Chrysler Firepower
