Re: 4 Speed behind a stroker
[Re: moparmojo]
#103463
08/12/08 11:12 AM
08/12/08 11:12 AM
Posts: 227 Tennessee
rj8806
Tennessee
Ok, I know this has probably been covered a billion times, but I got to thinking while at the Nats looking at the Keisler TKO600 how much power/torque the 4 speed would take. Any vendors selling an upgraded 4 speed?
Actually the TKO-600 is conservatively rated at 600hp and 600 ft/lbs. Our Tremec rep once told me that they put a TKO-600 on a dyno and hit it with 1400ft/lbs of torque and the jig holding the TKO broke, not the TKO but the jig holding it. ![](/ubbthreads/images/graemlins/shock.gif)
Take that for what it's worth but I trust them whole heartedly. I personally had a TKO-500 (rated conservatively at 500hp and 500 ft/lbs) in my '90 Mustang with a 347 stroker motor and a Kenne Bell S/C. One of my last dyno runs on a mustang dyno, netted me 603RWft/lbs. That means I was over the advertised limit of the TKO-500 by about 130 ft/lbs. If you've ever met or saw a typical mustang guy driving and beating on his mustang, then you have a clear picture of how I drove this car. The TKO lasted for over 2 years on it before I had an engine fire and the car was a total loss.
On another note, we have many customers out there with B and E body Mopars that are putting out way more than the 600hp and 600 ft/lbs that the TKO-600 is supposed to be able to handle and they are running fine.
The only limits of the TKO that I am aware of, is it's capability to shift smoothly at 6000+rpm shifts. The biggest complaint I hear is from guys who constantly miss 2nd to 3rd shift when power shifting. The key to hitting that shift is to use the palm of your hand and when in 2nd, simply throw the shifter STRAIGHT forward out of 2nd and it will find 3rd on it's own. If you try to shift it like you do a 4 speed(up, over and up again), you will miss 3rd every time. Also, if your are trying to shift it over 5900-6000 rpm's, the shift quality becomes sketchy at those rpm's. If your motor is capable of shifting at a higher rpm than 6000, then the TKO is not for you. Just so you know, my mustang redlined at 5900. I shifted it consistently at 5800 all the time with no missed shifts(due to transmission error).
I am not trying to sell you on a TKO, only trying to arm you with the most accurate information I have about the TKO so you can make an informed decision about which way to go. Good luck in your decision and please let me know if I can be of further help. ![](/ubbthreads/images/graemlins/thumbs.gif)
Richard Tech Support Keisler Engineering
[Re: moparmojo]
#103465
08/12/08 10:48 PM
08/12/08 10:48 PM
Posts: 8,926 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
TKO has bigger,stronger gears and shafts than A833
A833's were good enough for stockers, super stockers and gas cars for years ! There will be a lot weaker links in the drivetrain than the 833 !
[Re: moparmojo]
#103469
08/13/08 10:24 PM
08/13/08 10:24 PM
DaytonaTurbo
Manitoba, Canada
With a Keisler, do you need to do any welding like in the factory 833 kits?
Installation is pretty similar in that if you needed an aftermarket floor hump with the 833, you'll need one with the keisler. Other than that, no welding. Everything else is a bolt-in.
[Re: 1fastrunner]
#103470
08/15/08 02:12 PM
08/15/08 02:12 PM
Posts: 869 Sugarloaf, PA. USA
JamiePasson
Sugarloaf, PA. USA
We can actually take your unit and change the gearset in it to make 4th gear .80:1 instead of 1:1. Therefore, since your trans already fits into the car, there is no modifying, changing bellhousings, shifters, crossmembers, driveshafts, etc. None of that stuff. You do end up with the 18 spline input shaft. If you started with an 18 spline, you keep the same clutch. If you started with a 23 spline, you need to get an 18 spline clutch which we have. However, this is an off the shelf clutch. It is not a special conversion deal that you don't know what you need when you need a clutch and thus causing you to be limited where you can get a clutch down the road. Anyway, as far as power capabilities. Can you break our unit, yes. Has anyone yet? Thankfully no. To date, we have a customer putting 893 lb/ft of torque through it in a 4000 lb car. So, unless he is lying to me, it is holding that thusfar. ![](/ubbthreads/images/graemlins/smile.gif)
