trans issue #1034377
07/17/11 07:39 PM
07/17/11 07:39 PM
virginia
1x59rr Offline OP
1x59rr  Offline OP
virginia
My car seemed to leave fine, when i shifted to 2nd got a load bang and that was it. No fwd gears, reverse works, fluid changes levels between park and N, sprag seems to be fine, there were no parts in the pan. Fluid gets changed and bands checked every 20-30 runs.
Mark
69 RR
Re: trans issue [Re: 1x59rr] #1034378
07/17/11 07:42 PM
07/17/11 07:42 PM
Florida STAYcation
dOoC Online penguin-006
The village idiot's idiot
dOoC  Online Penguin-006
Florida STAYcation
How much line pressure ? ...
Re: trans issue [Re: dOoC] #1034379
07/17/11 07:45 PM
07/17/11 07:45 PM
baldwinsville new york
a493demon Offline
a493demon  Offline
mine did the same 2 week's ago but no bang. prob. the platery gear? bradp.s i did find alum. in the pan but have not taken it apart yet.
Re: trans issue [Re: a493demon] #1034380
07/17/11 07:47 PM
07/17/11 07:47 PM
Florida STAYcation
Florida STAYcation
PROB blew-out one of the rubber seals in the rear clutch pack.
Re: trans issue [Re: 1x59rr] #1034381
07/17/11 10:20 PM
07/17/11 10:20 PM
NC
440Jim Offline
440Jim  Offline
NC
No FWD gears and reverse working is typically a symptom of the rear clutch (forward gear clutch) not working. But it might be something else. The bottom line from your view in the pan, it will require the trans to come out to fix it. Then it might be more obvious what happened.
The loud noise makes me wonder if it is something else.
Let us know.
