Date coded distributor #1033538
07/16/11 10:29 AM
07/16/11 10:29 AM
85086
moparpollack Offline OP
Lil Herman
Lil Herman
85086
My 68 Roadrunner's original distributor is long gone. Where do I look to find the date code for a replacement so it will time match the car? Would it be the engine block date or the fender tag date?
55 Pick up 56 Plaza 63 D100 step side 67 Coronet, 68 Roadrunner, 69 Super Bee, 69 Coronet 500 convertible, 70 Roadrunner Post, 79 D150 360, and a severe case of Mopar a,d,d
Re: Date coded distributor [Re: moparpollack] #1033539
07/16/11 02:11 PM
07/16/11 02:11 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Engine block assembly date of course .
Re: Date coded distributor [Re: JohnRR] #1033540
07/16/11 02:19 PM
07/16/11 02:19 PM
85086
Lil Herman
Lil Herman
85086
Sorry John I'm not a numbers guy like you.
But really the carb is correct I have no I idea about the date coding.
Re: Date coded distributor [Re: moparpollack] #1033541
07/16/11 02:40 PM
07/16/11 02:40 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
What are the numbers on the carb ? There is a letter and a number before the part number , that is the date , example A8 , the distributor will have a 2 or 3 digit code , week of the year built and the year .
Re: Date coded distributor [Re: JohnRR] #1033542
07/17/11 10:35 AM
07/17/11 10:35 AM
S.W. Florida
blkbee6pack Offline
blkbee6pack  Offline
S.W. Florida
Was the distributor put on the engine at the block assembly date? How would they know which one as to which transmission was to be put in? If SBD on fender tag is after block assyembly date.
Re: Date coded distributor [Re: moparpollack] #1033543
07/17/11 10:45 AM
07/17/11 10:45 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Just to give some time line reference as is for example only.
this is a 1969 B-body 440 automatic.
July 3rd 1969 scheduled build date
Re: Date coded distributor [Re: blkbee6pack] #1033544
07/17/11 11:04 AM
07/17/11 11:04 AM
85086
Lil Herman
Lil Herman
85086
This is why I asked. But wouldn't the 4 speed cars have the cranks drilled for the input shaft? They must of had a method for automatic transmission and standard transmission motors.
Re: Date coded distributor [Re: moparpollack] #1033545
07/17/11 12:11 PM
07/17/11 12:11 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
John Kunkel posted a picture showing the engine assembly line with engine blocks being assembled that had bellhousings bolted on empty blocks, machining the bellhousing casting was part of the engine machining so they already knew what engines were 4 speeds and what engines were not BEFORE the engine had the first part installed.
The distributor will OBVIOUSLY be assembled in advance of the engine assembly , how long ?
Also from another thread there seems to be just a few date codes as if these were done in large batches ? Bill Rolick sells repopped tags and I think there are only certian dates ???
Re: Date coded distributor [Re: JohnRR] #1033546
07/17/11 01:19 PM
07/17/11 01:19 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
IN GENERAL there was a wide range of acceptable dates, as mentioned most distributors were built in batches. The date that is critical is that the distributor date preceeded the engine assembly date. With shipping time a consideration I would think the closest to the engines assembly date you will likely see a distributor assembly date would be around 2 weeks prior, but most I've seen were a month or 3 earlier. When going the other direction, I have seen A LOT of distributors assembled over a year prior to engine assembly dates (for instance it's common for 71 Hemi's to have 1969 dated distributors).
Re: Date coded distributor [Re: moparpollack] #1033547
07/17/11 01:33 PM
07/17/11 01:33 PM
cbusters Offline
cbusters  Offline
Engine build date is 60 days prior to car assembly date, and the distributor is 30 days before car assembly date, according to reference material. I think the engine may have the distributor installed while it is waiting for its car to be built, so probably 30 days prior to engine assembly date would be more accurate. Unless the distributor is installed when the car is assembled. You can get dizzy with the calculations. I will add that the dates are approximate. We can't have an assembly line shut down just because an engine has separation anxiety from its builder!
Re: Date coded distributor [Re: cbusters] #1033548
07/17/11 01:36 PM
07/17/11 01:36 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Actually you can leave the cars SPD out of the math picture, the distributor was in the engine before the engine was installed into the car.
Re: Date coded distributor [Re: cbusters] #1033549
07/17/11 02:24 PM
07/17/11 02:24 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Did you type that with a straight face ??? I have rarely found that to be the case on muscle era mopars, actually only seen it once .
Re: Date coded distributor [Re: JohnRR] #1033550
07/19/11 02:00 PM
07/19/11 02:00 PM
DFW
68RRFlyer Offline
68RRFlyer  Offline
DFW
My 69 Charger RT/SE was built 12-12, and my engine date on the pad is 12-9. 3 days prior. Date on the intake is 12-2. Numbers matching, with the VIN on the pan rail, and I know the history of the car back to day 1, so I know it's all original in there. Carb is out at Scott's getting rebuilt, but I am missing my original distributor so I'm on the hunt for a correct one as well (440, auto, non A/C if anyone cares...hint hint )
Cheers
Re: Date coded distributor [Re: 68RRFlyer] #1033551
07/19/11 03:39 PM
07/19/11 03:39 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Cheers
You mean like the one 6970gtx has pictured above
Re: Date coded distributor [Re: Morty426] #1033552
07/19/11 06:06 PM
07/19/11 06:06 PM
DFW
68RRFlyer Offline
68RRFlyer  Offline
DFW
Would be perfect for my app, but the date is off.
Re: Date coded distributor [Re: 68RRFlyer] #1033553
07/19/11 07:07 PM
07/19/11 07:07 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
I think you can get Bill Rolik to make you a tag
Re: Date coded distributor [Re: Morty426] #1033554
07/20/11 08:16 AM
07/20/11 08:16 AM
PA
BTTG Offline
BTTG  Offline
PA
The distributor bodies themselves are not stamped.....only the tag contains the part # and date code??
If so is buying a remanafactured points distributor a good option? they are cheap <$40 and add a tag for $25(the repro tag does look different than the one in GTX6970s picture)?
http://www.billrolikenterprises.com/proddetail.asp?prod=2875758
Re: Date coded distributor [Re: BTTG] #1033555
07/20/11 09:34 AM
07/20/11 09:34 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
That would be FRAUD , passing off something that it is NOT ...
But some bodies are stamped .
Re: Date coded distributor [Re: JohnRR] #1033556
07/20/11 12:39 PM
07/20/11 12:39 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
That would be FRAUD , passing of something that it is NOT ...
Yeah I think it's the 68 and olders that are stamped on the body
Re: Date coded distributor [Re: JohnRR] #1033557
07/21/11 02:24 AM
07/21/11 02:24 AM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
Early November '68 build date.
Seeking:
1969 St. Louis plant VINs, SPD, and VONs.
Over 2,000 thanks to you!
