Re: fireing stroke
[Re: BADDBOB]
#1033520
07/16/11 09:52 AM
07/16/11 09:52 AM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
thanks for the info..should the timing marks both be at 12 o clock ? are my books wrong
Install with crank sprocket at 12 and the cam at 6. Makes it easier to line up straight with the shorter distance between. Think about it: then turn the engine over 1 full turn and you will now be at crank at 12 and the cam at 12. Crank shaft makes 2 revolutions to every 1 of the cam shaft
Re: fireing stroke
[Re: BADDBOB]
#1033523
07/16/11 10:09 AM
07/16/11 10:09 AM
Posts: 75,005 U.S.S.A.
JohnRR
U.S.S.A.
No they are not wrong , you line up the dots on initial install to get the chain and gears installing correctly, this position is the compression stoke/firing of cylinder #6 . BUT you are ASSuMeing the the timing set is correct , if your engine is having issues you should probably get a degree wheel on there and make sure the chain set is right .
Re: fireing stroke
[Re: BADDBOB]
#1033524
07/16/11 10:13 AM
07/16/11 10:13 AM
MoparforLife
Upper Midwest
that,s the info I needed..thanks smart guy
Like I said in the post above 12 & 12 is actually the same as 12 crank and 6 cam. It is easier to get a straight line with the short distance. Comes out the same. 6 of one half a dozen of the other.
Re: fireing stroke
[Re: BADDBOB]
#1033526
07/16/11 05:03 PM
07/16/11 05:03 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
Your books are correct. The books show the cam installed ATDC between the exhaust and intake overlap strokes. Not the top of the compression stroke/fire.
Lots like yourself think the piston is at the ATDC of the comp stroke with the cranks mark at 12 and the cam at 6 lined up, its not.
Re: fireing stroke
[Re: Sport440]
#1033527
07/16/11 05:17 PM
07/16/11 05:17 PM
MoparforLife
Upper Midwest
Right number 6 is. Either way don't worry about where the piston is when you install the chain and sprockets. It will take care of itself. Forget that the pistons are even there till you install the intermediate shaft and distributor.
