Holley on '69 440 4-spd do I need throttle extension &
#1032977
07/15/11 02:47 PM
07/15/11 02:47 PM
Posts: 21,555 N.E. OHIO, USA
A12
N.E. OHIO, USA
Replacing the Carter AVS on a '69 GTX 440 4-Speed, do I need the throttle extension (Holley P/N 20-7)?? This is a 4-Speed car and of course no kickdown linkage so do I need the stud (Holley P/N 20-36) that the kickdown linkage is on just for the throttle return spring???? I was told by a "sales representative" at one of the vendors that I needed both of these items for Chrysler Application but looking at it on the 440 and having had this same Street Avenger on my '68 AUTOMATIC road runner (less CFM of course) I could actually hook the throttle cable to the stock Holley carburetor linkage that is provided. The throttle cable would have about a 5-10 degree angle but nothing that I can see would cause a problem. What do you think; no extension, extension only to get the throttle cable straight, or the extension with the stud and use the stud for the return spring??? T.I.A. MikeR
Re: Holley on '69 440 4-spd do I need throttle extension &
[Re: A12]
#1032982
07/15/11 06:15 PM
07/15/11 06:15 PM
Posts: 26,039 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The throttle lever extension does more than configure the transmission linkage, it extends the throttle stud farther outward to line up with the throttle cable. If you hook the throttle cable end directly to the Holley lever the cable aims more inward.
[Re: A12]
#1032983
07/15/11 06:29 PM
07/15/11 06:29 PM
Posts: 75,126 A Banana Republic near you.
JohnRR
Jeff thanks. Have you used a Holley with a stock cast iron intake manifold? I have to use at least a 3/8" (or more) thick gasket under the carb for it to clear the secondary linkage and the idle speed on the choke on the other side. I may even have to remove/grind some of the cast iron manifold for the secondaries to work at the diaphram rod?????? The last Holley I put on was with an Edelbrock aluminum manifold and it bolted right on with a fairly thin gasket....not so with the stock cast iron manifold . I'm afraid that the stock air cleaner will hit the hood if I use enough thickness carb to intake gaskets. I have to see how thick/tall I can go or grind the intake at the choke thermostat well to get everything to clear. Things that I think will be bolt on or easy lately just haven't been
Thanks,
MikeR
the 69 and early intakes were not designed to accept a holley carb , you'll have to grind on the intake or put a 1/2" spacer under the carb ... but you know that .
[Re: Mr.Yuck]
#1032985
07/15/11 07:27 PM
07/15/11 07:27 PM
A12
N.E. OHIO, USA
just order a 1/2" 4 hole spacer.
Have to check hood to unsilenced O.E. air filter cover clearance with 1/2" but may just get out the grinder
It also screws up the stock coil mount have to figure that out. Have some 1" - 1-1/2" flat stock that I can maybe offset it forward a little and keep it in about the same area.
Thanks John and Jeff
MikeR
[Re: A12]
#1032986
07/15/11 10:00 PM
07/15/11 10:00 PM
Posts: 1,051 Slidell, La.
doctor_mopar
Slidell, La.
I put a Holley 750 Double Pumper on a 440 GTX 4 speed. It worked best to use the throttle lever adapter. I also ground some material off the manifold for clearance. Used a little thicker gasket. I also bought the aftermarket coil bracket that moves the coil out of the way, and the fuel line kit that made it all look as if it were a factory installation. The bracket and fuel line are made/ sold by Fabulous Fabrications. 303-666-9882 .These parts a well worth the few dollars they cost. I used the stock air cleaner that cleared the hood.
------------------------ It doesn't matter what you do.........As long as you look good doing it !
[Re: A12]
#1032987
07/16/11 10:13 AM
07/16/11 10:13 AM
JohnRR
MikeR
That's the other problem you run into , I took a piece of 1/4" 6061 and made a plate to do the opposite , move the coil to the correct location when using a DP4B which has the coil on the other side.
