Flex fan or fan clutch??? Which to use??????
#103287
08/11/08 05:15 PM
08/11/08 05:15 PM
Posts: 1,365 So Cal
GoManGo70Bee
super street
super street
So Cal
What are the ups and downs to both? Which work better? Thanks!! ![](/ubbthreads/images/graemlins/wave.gif)
70 Superbee 383 4 speed
70 Hurst 300
67 Dart sedan
74 Ramcharger
03 Hemi Ram 1500 4X4
Re: Flex fan or fan clutch??? Which to use??????
[Re: GoManGo70Bee]
#103292
08/11/08 06:28 PM
08/11/08 06:28 PM
Posts: 18,160 Mass
DAYCLONA
Mass
Thanks!!
Neither,,,,,,use a fixed 5 or 7 blade factory fan,....it's not like that 5 HP loss is gonna be noticed........but 200+ degrees F....will
And be sure to use a full shroud...... ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: ahy]
#103293
08/11/08 06:35 PM
08/11/08 06:35 PM
Posts: 5,118 Alone in the darkness
gamagoat6x6
super street
super street
Everything I own has a big 7 blade thermal clutch fan and if I get a car that doesn`t it gets one soon. A big one will move more air than anything else when required or just go along for the ride when it isn`t needed using almost zero power. Best of both worlds and they`re quiet when disengaged. Why didn`t everything get `em from the factory? because they`re expensive to produce so they were reserved for things that really needed good cooling like top of the line heavily optioned cars and HD trucks. If it`s good enough to cool this hard workin` beast it`s sure good enough for a car application. ![](http://i176.photobucket.com/albums/w175/gamagoat6x6/DCP01172.jpg)
`02 RAM2500 SPORT V10 4x4
`06 GMC sierra
NO cars
[Re: DAYCLONA]
#103295
08/11/08 07:00 PM
08/11/08 07:00 PM
Posts: 1,396 Mass
dgc333
Mass
Thanks!!
I have read that you can save up to 20HP with a clutch fan over a fixed blade fan.
[Re: dgc333]
#103297
08/11/08 07:09 PM
08/11/08 07:09 PM
Posts: 1,482 Lake Orion, MI
goldduster318
Lake Orion, MI
my car has a 5-blade clutch fan...actually out of an early 80's D150 pickup. you just have to measure to make sure the diameter is right for the fan. Works wonderfully and I could definitely tell the difference between it and the 9 blade fixed fan it replaced.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
[Re: Black_Sheep]
#103300
08/12/08 06:46 AM
08/12/08 06:46 AM
Posts: 21,088 Niles , Ohio
therocks
Niles , Ohio
I agree with 383 man.ve had the same stainless flex on my 12.5 built 440 for at least 15 years.No problems and it runs under 190 all day.Ive run them since the 70s when I plowed snow.I run only stainless.Only had one fan come apart and it was a factory one.My rad in the 65 is stone stock never been touched and still cools great.We also run them on my kids built 360 and the 413.Rocky
Chrysler Firepower
[Re: therocks]
#103302
08/12/08 07:16 AM
08/12/08 07:16 AM
Posts: 30,537 Florida STAYcation
dOc !
The village idiot's idiot
Florida STAYcation
NONE of the above !! ![](/ubbthreads/images/graemlins/laugh2.gif) Get an electric puller ...works ONLY when necessary. Both the flex and clutch fans "work" alot of the times ...when their assist is not needed !!
[Re: DAYCLONA]
#103303
08/12/08 07:19 AM
08/12/08 07:19 AM
Posts: 1,396 Mass
dgc333
Mass
The key word being "up to"............kinda like the lottery......"you could be a winner"......
Yea but it will always free up more power over a fixed blade fan and with the exception of the one case you sited it has no down side.
Most all heavy duty and ac cooling systems came from the factory with a clutch fan (with the exception of your example). The advantage is they have a more agressive blade design that will move more air at idle where the fan is needed and rob less HP at speed when its not needed.
[Re: dgc333]
#103304
08/12/08 11:11 AM
08/12/08 11:11 AM
7 blade clutch for me. always works (until they wear out) but they work well for me
#103305
08/12/08 05:27 PM
08/12/08 05:27 PM
therocks
Niles , Ohio
If you have to worry about maybe 5 HP you need to build a better motor period.Ive seen too many hi buck elec and clutch fan setups with big expensive radiators that overheat.My 25 buck stainless fan has been doing the job with an almost 50 year old rad for years.Ill stick with it and keep upwards of between 200 and a thousand or more dollars in my pocket.Rocky
Chrysler Firepower
