Rocker springs..and oil slinger missing
#1032545
07/14/11 04:28 PM
07/14/11 04:28 PM
Posts: 576 Hr up from KCK
451 D*O*D*G*E
Hr up from KCK
Anybody NOT run the springs on the rocker shaft for b engines?Mine didnt have them or a oil slinger on the crank??
1970 Challenger R/T clone
2010 Dodge Journey R/T black,awd,
Re: Rocker springs..and oil slinger missing
[Re: 451 D*O*D*G*E]
#1032546
07/14/11 04:39 PM
07/14/11 04:39 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
Don't worry about the slinger. It is more shield to keep excess oil off the crank seal and help prevent leakage. Modrn seal technology is preventing this. It is cupped over the seal helping to keep oil off the seal. If it were cupped back toward the chain area then it would catch oil and 'sling' the oil back at the chain but it is not. The chain gets plenty of oiling with the crankshaft splash and fogging from the pan and the oil flow from the lifter valley. Never seen a dry chain yet. BTW some came with them some without from the factory. ![](/ubbthreads/images/graemlins/beer.gif) You need springs or spacers to keep the rockers in place on the valve stems.
[Re: MoparforLife]
#1032547
07/14/11 04:44 PM
07/14/11 04:44 PM
451 D*O*D*G*E
Hr up from KCK
It has steel rings spacing the rockers but does it need the springs if it has these rings and the bolt spacers?
Who has the best deal on HD or stock stamped rockers?Iron are out for now and i have a hydraulic cam. I need to order new ones asap! Thanks!!!
[Re: JohnRR]
#1032552
07/14/11 05:50 PM
07/14/11 05:50 PM
451 D*O*D*G*E
Hr up from KCK
John thanks so much!I will send you my addy and can paypal you the shipping.
With the ductile they were 26 a peice at summit!Thats out of my budget.I will go look at Mancini,will i be able to use my push rods with balls on ends?
[Re: 451 D*O*D*G*E]
#1032554
07/14/11 06:00 PM
07/14/11 06:00 PM
Posts: 75,094 A Banana Republic near you.
JohnRR
With the ductile they were 26 a peice at summit!Thats out of my budget.I will go look at Mancini,will I be able to use my push rods with balls on ends?
With the Mancini rockers yes they are stamped rockers .
The crane kit I thought was about $350 ? You don't buy them separately.
[Re: MoparforLife]
#1032555
07/14/11 06:02 PM
07/14/11 06:02 PM
Posts: 30,486 Florida STAYcation
dOc …
The village idiot's idiot
Florida STAYcation
![](/ubbthreads/images/graemlins/laugh2.gif)
...if that was SO ... the ENGINEERS at Chrysler would have called-it a SHIELD ... ![](/ubbthreads/images/graemlins/grin.gif)
[Re: 451 D*O*D*G*E]
#1032556
07/14/11 08:32 PM
07/14/11 08:32 PM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
Get about a foot of 7/8" I.D. thin wall stainless tubing,measure the width you need and have a machine shop or someone with a lathe cut them about .040 short of what you need then get about a dozen each of .015 and .030 shims,you can then space them perfectly for rocker arm/valve stem alignment.It takes a little time but will save you bunch and well worth the effort. ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: dOc …]
#1032557
07/14/11 10:08 PM
07/14/11 10:08 PM
MoparforLife
Upper Midwest
Slings oil off the seal area. Chain benefits are minimal. Get plenty of oil without it. Do what ever turns your crank. Never seen a dry chain yet big or small block with or without. Course I have only been dabbling in this for nearly 45 years. ![](/ubbthreads/images/graemlins/shruggy.gif)
[Re: MoparforLife]
#1032558
07/15/11 04:25 AM
07/15/11 04:25 AM
dOc …
Florida STAYcation
45 years of dabbling ? ... well GET DOWN to brass-tacs and do some REAL WORK !!
And I know that you have on this topic before. DON'T argue with me ...call up CTC and argue with them ... ![](/ubbthreads/images/graemlins/tsk.gif)
