I am bout to loose my mind.From the top.
I bought the piston stop you all said and with my heads on i had to,it worked great got equal numbers on both sides.So i took the stop out and turned the engine(not the degree wheel) to tdc.
I turned the engine clockwise and found max lifter lift(solid lifter,dial mounted solid reading retainer.)....i then zero'ed the indicator.Turned couter clockwize .150 then back to .100.No what i get a reading of 76.Ok now i go clockwise .100 and i get a reading of 116 or so..never enough to to add then divide to even get in the ballpark of 104-108.What in tarnation am i doing wrong!!!!!!!!!!!!
I never check the timing pulling it apart it has a multi postion crank sprocket with the circle being left of the key.I installed a 4 degree bushing in the timing gear to get close then take the reading,,but the .100 after peak lift is never enough degrees to come out right.Help me please..my last day off for quite awhile
