Heat shield for brake lines #1032259
07/14/11 12:10 AM
07/14/11 12:10 AM
BC Canada
62440 Offline OP
62440  Offline OP
BC Canada
I just installed all new brake lines and proportioning valve. I couldn't help but notice the close proximity of the headers to the brake lines, about 2" there abouts. Should that be a concern ??? I'm thinking so. What do you guy's do ??? I'm thinking about a thin piece of aluminum or would that just collect and radiate the heat ???
Re: Heat shield for brake lines [Re: 62440] #1032260
07/14/11 05:41 PM
07/14/11 05:41 PM
BC Canada
62440 Offline OP
62440  Offline OP
BC Canada
Has no one had this problem ???
Re: Heat shield for brake lines [Re: 62440] #1032261
07/14/11 06:38 PM
07/14/11 06:38 PM
N.E Indiana
repad Offline
super street
repad  Offline
super street
N.E Indiana
A shield should work, have you considered wraping the close areas with heat tape?
Re: Heat shield for brake lines [Re: repad] #1032262
07/15/11 03:04 AM
07/15/11 03:04 AM
BC Canada
62440 Offline OP
62440  Offline OP
BC Canada
I've thought about a aluminum heat shield with a stick on Thermo-Tec sheet. and I have some DEI hard bendable heat shield tube. I'm wondering what others do. Or is it even a problem ? Is 2" clearance normal for header to brake lines ???
Re: Heat shield for brake lines [Re: 62440] #1032263
07/15/11 04:31 AM
07/15/11 04:31 AM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
2" is tooo close IMO. A combo of a shield and heat/header tape is a good idea.
Re: Heat shield for brake lines [Re: dOc !] #1032264
07/15/11 01:31 PM
07/15/11 01:31 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Fire sleeve - insulated, pretty much burn-proof, available in orange or silver and in a variety of sizes.
