Page 1 of 3 1 2 3
thrust bearing issues #1031919
07/13/11 01:53 PM
07/13/11 01:53 PM
Houston, Texas
TheOtherDodge Offline OP
Houston, Texas
I think I wiped out my thrust bearing on the new motor already. I have measured .065 worth of movement and can visibly see it when I rev the motor and watch the crank trigger wheel in relation to the pickup.
I don't believe it is the converter, but talked to them anyways and they don't think it is either, mainly because Im only running 4.7 lbs of boost right now. It is a PTC unit.
What do you guys think? Oiling issue to the thrust bearing?
I have not taken it apart yet.
Re: thrust bearing issues [Re: TheOtherDodge] #1031920
07/13/11 02:12 PM
07/13/11 02:12 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Is this the second time for this issue? How much clearance did you have when assembled? Possible alignment problem? Whats the converter to flexplate clearance?
Re: thrust bearing issues [Re: TheOtherDodge] #1031921
07/13/11 02:18 PM
07/13/11 02:18 PM
Their is only one thing that usually causes thrust bearings to die, that is pressure(forward or rearward thrust )on the crankshaft
Re: thrust bearing issues [Re: Cab_Burge] #1031922
07/13/11 02:25 PM
07/13/11 02:25 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Naa,there are other causes as well. I do agree that is a possibility however.At least the crank being pushed forward(never seen a crank sucked back,but I haven't seen everything). Did this block have aftermarket main caps installed?
Re: thrust bearing issues [Re: goldmember] #1031923
07/13/11 02:37 PM
07/13/11 02:37 PM
Houston, Texas
Houston, Texas
Yes, second time this has happend, but the first time, we changed converters and dont know if the thrust problem was there at that time.
The converter turns freely when not bolted to the flex plate.
The block does have aftermarket billet caps.
Re: thrust bearing issues [Re: goldmember] #1031924
07/13/11 02:43 PM
07/13/11 02:43 PM
Belt driven superchargers can cause a lot of problems when thier not installed correctly, not saying his is but they can and have cause lots of problems on crankshafts Two different sets of main bearings with the same problem Time to find the cause All problems on cars are fixable, some are harder to diagnose than others
Re: thrust bearing issues [Re: TheOtherDodge] #1031925
07/13/11 02:46 PM
07/13/11 02:46 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
The converter turns freely is not the info needed. What is the distance between the converter mounting pad and the flexplate? What did the thrust bearings look like that were removed from the engine on the first go round? I'd be concerned with the main cap installation if it were mine.
Re: thrust bearing issues [Re: goldmember] #1031926
07/13/11 02:55 PM
07/13/11 02:55 PM
Crossville,TN
526ciduster Offline
526ciduster  Offline
Crossville,TN
Make sure the converter is not hitting the crank bolts. You can have flexplate clearance and the converter will hit the bolts.
Outlaw 10.5 526ci, F3R procharged tfx hemi, Big Stuff 3 PTP RACING
Re: thrust bearing issues [Re: Cab_Burge] #1031927
07/13/11 02:56 PM
07/13/11 02:56 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Yep,I left out "the belt driven supercharger" as he doesn't have one. You are right that this problem needs to be found cause it would sure stink to do this over again.I had a mild 360 come through last year that was built by a local guy. The thrust bearing was trashed in less than 100 street miles,I could not believe what I found,but it was improper assembly that caused the problem.
Re: thrust bearing issues [Re: 526ciduster] #1031928
07/13/11 02:59 PM
07/13/11 02:59 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Re: thrust bearing issues [Re: TheOtherDodge] #1031929
07/13/11 03:33 PM
07/13/11 03:33 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Should have about 3/8" movement fore and aft on the
converter(not bolted up)... if not it cant grow
with the heat and torque which can cause ballooning
in the conv to allow it to move rearward
Re: thrust bearing issues [Re: MR_P_BODY] #1031930
07/13/11 03:44 PM
07/13/11 03:44 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Which side of the thrust was chewed up last time?
Both, front or back?
Re: thrust bearing issues [Re: MR_P_BODY] #1031931
07/13/11 03:48 PM
07/13/11 03:48 PM
Savannah, GA
mopar400 Offline
mopar400  Offline
Savannah, GA
I had the same thing happen on my 440 yrs ago on the rear thrust surface. Found the Clevite bearing was the issue. The thrust surface was too soft on the bearing. We found bearing material in the oil filter. From memory the bearing material was real soft and a silver color. It could be easily scraped away with your finger nail. We ordered another set of Clevites and the thrust surface was a copper color. Engine was ran with those bearings for 4 years without another issue. I've seen 2 sets w/ the soft material. This was around 2000. I can't remember part #'s anymore.
Re: thrust bearing issues [Re: mopar400] #1031932
07/13/11 04:24 PM
07/13/11 04:24 PM
Houston, Texas
Houston, Texas
I guess I have some things to check.
As far as I remember, I had about 1/8" to 3/16" between the converter mounting pad and flex plate before bolting, but I dont remember exactly. I was enough for me to not be concerned at the time.
I have not taken the current thrust bearing out, but the previous one the entire rear portion was gone. Matter of fact, it took out the thrust on the crank!
Re: thrust bearing issues [Re: 526ciduster] #1031933
07/13/11 04:30 PM
07/13/11 04:30 PM
Houston, Texas
Houston, Texas
"Make sure the converter is not hitting the crank bolts. You can have flexplate clearance and the converter will hit the bolts."
How would the converter hit the crank bolts unless it is really balooning..or am I missing something?
Re: thrust bearing issues [Re: TheOtherDodge] #1031934
07/13/11 04:30 PM
07/13/11 04:30 PM
Houston, Texas
Houston, Texas
Goldmember you said "The thrust bearing was trashed in less than 100 street miles,I could not believe what I found,but it was improper assembly that caused the problem."
How was it improperly assembled?
Re: thrust bearing issues [Re: 526ciduster] #1031935
07/13/11 04:48 PM
07/13/11 04:48 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Even if the converter is hitting the crank bolts or if there is a flexplate pull-up problem, this is local to the rear flange and shouldn't cause forward thrust on the thrust main.
Re: thrust bearing issues [Re: John_Kunkel] #1031936
07/13/11 04:58 PM
07/13/11 04:58 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Only if the conv has enough room to grow and not bottom
out in the pump drive... other wise it bottoms in the
pump drive and then pushes forward on the crank
Re: thrust bearing issues [Re: TheOtherDodge] #1031937
07/13/11 06:02 PM
07/13/11 06:02 PM
ontario canada
mac56 Offline
mac56  Offline
ontario canada
I had one converter that had an anti balloon plate welded around the snout and it would hit the bolts before it closed the gap for the flex plate bolts so even though it looked like a gap it really was up tight.
Re: thrust bearing issues [Re: mac56] #1031938
07/13/11 06:31 PM
07/13/11 06:31 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Even if the flex plate had some bind it wouldnt push
forward... it has to bottom out in the pump drive
to push the crank forward
Page 1 of 3 1 2 3
