Page 7 of 8 1 2 3 4 5 6 7 8
Re: thermoquad VS. Holley 750 DP [Re: theclutcher] #1031824
07/19/11 11:53 AM
07/19/11 11:53 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Ever take one apart to see if those boosters could be repro'd and fit into a std TQ?
I imagine some of the tricks that went into the Comp Series design could be incorporated into the std TQ's, No?
I've taken many of them appart but haven't gone into any frankenstein experiments with the boosters, mainly because I haven't really found the need to. I suppose anything is possible if you played with them enough.
not sure what boosters are being talked about but i have read where you can cut out the outer ring of the booster on the 850 TQ making it about 1000 cfm's, and if you remove the choke plate and related shafts add another 60cfm's. BTW these TQ's are also popular with the big cube Buick guys.
To make an 850 Comp series into 1000cfm, cut outer ring?
any 850 TQ, but will need to be jetted up i suspect
Re: thermoquad VS. Holley 750 DP [Re: ademon] #1031825
07/19/11 01:50 PM
07/19/11 01:50 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Jetting of any carb will depend on the engine combo underneath it as well as other factor like altitude etc.
Re: thermoquad VS. Holley 750 DP [Re: ScottSmith_Harms] #1031826
07/19/11 02:05 PM
07/19/11 02:05 PM
charlotte,nc
pyp1000 Offline
pyp1000  Offline
charlotte,nc
here is what i have noticed about this debate: 1) guys who hate thermoquads will never use them
2) demonsizzler is mentioned with glowing reviews in regards to thermoquads
3) demonsizzler does not chime in nor toot his own horn (I have no idea if the 'sizz toots anything else )
4) I have run out of things to say.
5) demonsizzler; expect a pm from my dad. We need a thermoquad set up, the right way!
Re: thermoquad VS. Holley 750 DP [Re: 68Bullit] #1031827
07/19/11 02:51 PM
07/19/11 02:51 PM
Under My Car
Mopar_Country Offline
Under My Car
Threads like these draw amazing attention. You get all different takes of course, but I can't help to wonder how many people who talk against the TQ's have ever even used one, let alone taken any time to learn and tune one??? Even just basic tuning
Yup, I was told when working on my TQ to chunk it in the trash can and buy a Holley. I asked why, have you ever run a TQ, the answer was no. The only real world experience this person had was what other people had told him. I run the 850 on my teen and it runs flawlessly. Would I ever run a Holley, maybe, but I got 60 bucks in my carb, when I can buy a quality piece for 60 bucks I might just try it.
As far as mileage comparing 2 318s one with Holley and numerically lower gears gets about the same as mine with numerically higher gears and a TQ, in fact mine might do just a tad better. Same body car.
Re: thermoquad VS. Holley 750 DP [Re: Mopar_Country] #1031828
07/19/11 02:59 PM
07/19/11 02:59 PM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
IIRC HotrodDave had a 850 TQ on his super MPG 318.
Re: thermoquad VS. Holley 750 DP [Re: Rug_Trucker] #1031829
07/19/11 03:17 PM
07/19/11 03:17 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Your right Walt
I also had a 770 street avenger for a while and it ran just as good but never got near as good of MPG.
Re: thermoquad VS. Holley 750 DP [Re: HotRodDave] #1031830
07/19/11 03:23 PM
07/19/11 03:23 PM
Rug_Trucker Offline
Rug_Trucker  Offline
Your right Walt
But the TQ is a piece of junk! Over carbed 318!
How could that be possible?
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: thermoquad VS. Holley 750 DP [Re: Rug_Trucker] #1031831
07/19/11 03:42 PM
07/19/11 03:42 PM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
A 1 1/2" primary carb(850) on a small-inch low-rpm MPG project ? ...
Re: thermoquad VS. Holley 750 DP [Re: dOoC] #1031832
07/19/11 05:19 PM
07/19/11 05:19 PM
Desert Tracker
HYPER8oSoNic Offline
Desert Tracker
Sure, why not? May not have "razor-sharp" performance, but it leaves room for "growth"!!
It's mostly about the NEEDED amount of airflow, NOT the TOTAL rating of the carb, Doc. Jetting, float height, choke unloader settings, acc pump settings do have an effect on performance (model depending)..BUT.. you CAN fit the TQ on a 318 and have decent performance!! Personally, a 360 TQ model would be about right for the '18.
"Stupidity is Ignorance on Steroids"
"Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
Re: thermoquad VS. Holley 750 DP [Re: HYPER8oSoNic] #1031833
07/19/11 05:30 PM
07/19/11 05:30 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
I'm like everyone else... have a big steaming pile of tq's which I can't bring myself to throw in the trash.
BUT.. this thread does get a guy thinking....
I believe the main reason the tq didn't get the popularity is because they are a pain in the junk to open up and tune or fix problems. Way to much finicky linkage and screws and garbage.
If you wanted to start from scratch, its a labour of love. By the time your done , if you sell it you might recoup your money you have into the carb kit.
It is a good design, but could have used a couple more mill into engineering.
Re: thermoquad VS. Holley 750 DP [Re: Rug_Trucker] #1031834
07/19/11 05:37 PM
07/19/11 05:37 PM
Desert Tracker
Desert Tracker
back-at-you. Pick up a TQ manual, for once, and find out why!! For "junk" to perform well on a 318, is NOT that it's a possibility, it's an EVERYDAY occurance!!
Re: thermoquad VS. Holley 750 DP [Re: RemCharger] #1031835
07/19/11 05:48 PM
07/19/11 05:48 PM
Desert Tracker
Desert Tracker
Good point!! When do you want to "rid" yourself of that pile of TQ's? Seriously,
there are combos built with the TQ (or TQ's - yes Scotty, I need more power! ) that run very strong. BTW they are NO HARDER to work on than a Holley.
Re: thermoquad VS. Holley 750 DP [Re: HYPER8oSoNic] #1031836
07/19/11 07:30 PM
07/19/11 07:30 PM
Florida STAYcation
dOoC Offline
dOoC  Offline
Florida STAYcation
HYPER - ...
WE are talking about a low-rpm MPG application ... NONE of what-choo mentioned above really has anything to do with that.
The primary vent SIZE is what matters ... and a 1 3/8 (I would think) would work the bestest there.
I have a 1 3/8 on my Discoverer motorhome(413 power) ...and it has performed GREAT. NO NEED to get into the secondaries uNder normal flat-road cruising operations at around 60 mph.
Re: thermoquad VS. Holley 750 DP [Re: dOoC] #1031837
07/19/11 08:47 PM
07/19/11 08:47 PM
Desert Tracker
Desert Tracker
HYPER - ...
Good for you, that you have chosen that size of primaries for YERR 413 'DISCO!! But Doc... contrary to the nonsence that's rattling in yerr
head, I made that point of primary sizes a-WHILE BACK!! Lay off the pipe!!
Re: thermoquad VS. Holley 750 DP [Re: dOoC] #1031838
07/19/11 11:08 PM
07/19/11 11:08 PM
Rug_Trucker Offline
Rug_Trucker  Offline
You never saw the thread?
Re: thermoquad VS. Holley 750 DP [Re: Rug_Trucker] #1031839
07/19/11 11:29 PM
07/19/11 11:29 PM
Florida STAYcation
dOoC Offline
dOoC  Offline
Florida STAYcation
Yes I saw it RT .. but it never registered that it was a 850. HONESTLY ...I think that some more MPG could be gotten with the 800 carb ... and MAYBE some-more with a reduction of the vent size ON TOP....or on the bottom.
Now to HYPER - ...will he EVER get his ride fixed ? ... ME THIMKS not ! ..
Re: thermoquad VS. Holley 750 DP [Re: dOoC] #1031840
07/20/11 11:54 AM
07/20/11 11:54 AM
Desert Tracker
Desert Tracker
Your problem is that you put a lot of time and effort into being an IRRITANT, instead of working YERR OWN PROJECTS!!
Re: thermoquad VS. Holley 750 DP [Re: HYPER8oSoNic] #1031841
07/20/11 08:06 PM
07/20/11 08:06 PM
Florida STAYcation
dOoC Offline
dOoC  Offline
Florida STAYcation
HYPER ....seriously ...take a break ..
Re: thermoquad VS. Holley 750 DP [Re: dOoC] #1031842
07/20/11 10:22 PM
07/20/11 10:22 PM
Desert Tracker
Desert Tracker
I'm eating a KitKat bar right now, what's
yerr problem!!
Re: thermoquad VS. Holley 750 DP [Re: ScottSmith_Harms] #1031843
07/21/11 07:03 AM
07/21/11 07:03 AM
Oakdale CT
gdonovan Offline
gdonovan  Offline
Oakdale CT
I have a new "aftermarket" electric choke model I picked up at Englishtown swap meet several years ago =)
You must have 1 of these? Known as "Super Quads", these are not Competition series carbs but rather an over the counter "One size fits all" replacement. Good carbs but not considered to be anything like the Competition Series units.
Looks like it.
I love the TQ's, going to run one on the GTX again when it comes out to play. The more I tinkered with it the faster the car would go!
