carb tuning? video added #1030753
07/12/11 01:21 AM
07/12/11 01:21 AM
pacific northwest
Stroker Scamp Online content OP
Stroker Scamp  Online Content OP
pacific northwest
so if the air gets better and your car doesnt improve does that mean its lean? explain your thoughts, thanks btw i run 84 jets square in a holley 950 no pv, car ets from 10.30 to a best of 10.14 no changes in tuning just weather
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: carb tuning? [Re: Stroker Scamp] #1030754
07/12/11 03:37 AM
07/12/11 03:37 AM
I would think that your motor is not running fat if it doesn't pick up when the air get better How much better weather are we talking about as far as actaul air temps, humidity and baro. pressure changes? My car slowed down .006( 6.688 ET 1/8 mile) when the air temps went from 71.4F with 40.2% humidity with Baro. Pres. of 27.39(actual) at 11.10 A.M. to 80.4 F with 28.7 % humidity and 27.34 B.P. at 1.39 PM in Madras this weekend with a 6.694 ET the MPH didn't change from 102.74 to 102.74 MPH The AFR on it are right at 12.8 to 13.3 AFR for the entire run now My intrepretations have alwyas been that if the car picks up when the air gets better the carb. jetting is fat IHTHs. BTW, I'm going to Woodburn in two weeks for the Mopar race so we will see what it does there now that it seems to have enough fuel supply for the entire run instead of running out from the starting line on like it was the last race there according to the wide ban
Re: carb tuning? [Re: Cab_Burge] #1030755
07/12/11 11:33 PM
07/12/11 11:33 PM
pacific northwest
pacific northwest
Cab, see ya there, I pretty sure im too lean I have a in car video and you can hear what sounds like a lean missfire, I will see if I can post it. I did not have the DA readings at this race but it was in the mid 70's fyiw
Re: carb tuning? [Re: Stroker Scamp] #1030756
07/14/11 02:00 AM
07/14/11 02:00 AM
pacific northwest
pacific northwest
heres a vid from in car what do you heer? http://www.youtube.com/user/kimkrzy#p/a/u/0/Zh2Y_B6uGHE btw i forgot to tun the camera off so you get a ride back to the pits
Re: carb tuning? [Re: Stroker Scamp] #1030757
07/14/11 10:40 PM
07/14/11 10:40 PM
pacific northwest
pacific northwest
give the video a listen and tell me what u think
Re: carb tuning? [Re: Stroker Scamp] #1030758
07/14/11 10:46 PM
07/14/11 10:46 PM
British Columbia
toddd Offline
toddd  Offline
British Columbia
How fresh are the plugs?
Mine did the same thing, but a plug change cleaned it up.
Is it me or does the miss go away near the end of the run???.
What is the jetting now?
Re: carb tuning? [Re: toddd] #1030759
07/14/11 11:04 PM
07/14/11 11:04 PM
SoCal
Brian Hafliger Offline
SoCal
seems like high rpm miss...hard to tell though.
Ever check valve springs for pressure?
Ever make a run and pull a plug? Any pics?
What's the jetting at now?
Spacer?
Do you run mufflers?
What plug?
Everything look good in the dist.?
Ever check ohms on plug wires?
What valve lash do you run?
Brian Hafliger
Re: carb tuning? [Re: Brian Hafliger] #1030760
07/15/11 12:13 AM
07/15/11 12:13 AM
pacific northwest
pacific northwest
Plugs may have 20 runs on them
never pulled a plug after the run
jetting is 84 sq no pv
1"spacer
bullet mufflers
ngk 8's
went thru the dist, wires and springs when i was chasing the backfire
I forgot to add that i added an air pan and no air cleaner, didnt see any slopping of gas from turbulence, i think ill try to add a bit of jet and see what it does next weekend
Re: carb tuning? [Re: Stroker Scamp] #1030761
07/15/11 12:21 AM
07/15/11 12:21 AM
British Columbia
toddd Offline
toddd  Offline
British Columbia
If you have a high rpm limiter...What is it set at?. I was having problems of it cutting in well before the # I had chosen.
What kind of ign box?
Re: carb tuning? [Re: toddd] #1030762
07/15/11 12:26 AM
07/15/11 12:26 AM
pacific northwest
pacific northwest
thats a thought msd 6al with a 7200 chip
Re: carb tuning? [Re: Stroker Scamp] #1030763
07/15/11 12:32 AM
07/15/11 12:32 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Pull the high rev chip and try it without a chip...
I've had multiple chips act up.... I have also had
a 7-al give me a high rev miss.... just a light miss
but it was there.... I changed boxes and it was gone
Re: carb tuning? [Re: MR_P_BODY] #1030764
07/15/11 12:44 AM
07/15/11 12:44 AM
pacific northwest
pacific northwest
did your miss sound like the one thats in my vid?
Re: carb tuning? [Re: Stroker Scamp] #1030765
07/15/11 12:48 AM
07/15/11 12:48 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I didnt listen to it... I dont try to analyze a miss
over a computer speaker
Re: carb tuning? [Re: Stroker Scamp] #1030766
07/15/11 12:50 AM
07/15/11 12:50 AM
SoCal
SoCal
That's very true Mike, and that could be why it's at high rpm only. Pull that chip out!
Brian Hafliger
Re: carb tuning? [Re: Brian Hafliger] #1030767
07/15/11 12:57 AM
07/15/11 12:57 AM
pacific northwest
pacific northwest
thanks guys ill let ya know how things go when i hit woodburn on 23rd/24th
Re: carb tuning? [Re: Stroker Scamp] #1030768
07/15/11 01:22 AM
07/15/11 01:22 AM
Sounds like it starts missing in the bottom of high gear Check all the plugs and spark plug wires, it might be a fuel delivery issue also. Do the simple stuff first and eliminate the hard stuff last I had a similar miss at the top of high gear that ended up being three spark plug wires, 4,6 and 8
Re: carb tuning? [Re: Cab_Burge] #1030769
07/15/11 03:24 PM
07/15/11 03:24 PM
sweden
sshemi Offline
sshemi  Offline
sweden
Im trying to remeber what caused my car to do the exact same thing.
It was not my rev limiter turned it off and rpms were 8300
And it was not lean but maybe fat.
Sh&% i cant remeber.
Re: carb tuning? [Re: sshemi] #1030770
07/31/11 10:42 PM
07/31/11 10:42 PM
Wi.
65_gt_rag_402 Offline
Wi.
you have a lean condition gong on
when you put the air pan on ... it has turbulance and running lean. need to jet up or put the filter back on and try it.
Had same condition on my dart.
65 DART GT RAGTOP mopars "AWESOME" 360 magnum stoker 402 Engine !!!!!!! ROCKS !!!!!!!!!! 11.0's on pump gas .
Re: carb tuning? [Re: 65_gt_rag_402] #1030771
08/02/11 02:47 AM
08/02/11 02:47 AM
pacific northwest
pacific northwest
put the air cleaner back on and seemed to help a bit but its still breaking up a bit, so the search goes on
Re: carb tuning? [Re: Stroker Scamp] #1030772
08/02/11 03:25 AM
08/02/11 03:25 AM
Missouri
StrokerPost Offline
StrokerPost  Offline
Missouri
Mike, is this "breaking up" all the time , only at WOT, or top end only? I ran into this a few years back on my Dart, tried jetting, diff plugs, redid all my ignition grounds, checked dizzy shaft for too much play, everything I could think of with no luck, even swapped in my back up 6AL. Then after reading an article about dizzy phasing I decided to check it out. Turns out it was firing JUST before the rotor moved past the electrode for any given cyl. So I corrected that and the breaking up or miss was gone. Mine was a topend miss just about the 1000' mark to the stripe. Just a thought.
